error in speaker client
  • error in speaker client
    Ok so I narrowed down (Rupp's recommendation to narrow down via plugins) the error i was seeing in the speaker client...
    so an FYI Blade...
    BLLAN puts those in there... i enabled/disabled many times to make sure.. even only had that one running and same...
    BLLAN does nothing with the speaker client that I can recall
    Cheers,
    Bob
      ok...
      just mentioning it..
      not killing me.. i just know if i disable it.. they go away...
        Very odd
        Cheers,
        Bob
          I had the same problem too with BLLAN. I had to disable the BLLAN to stop the "Rebuilding VR commands due to configuration change" message from recurring every 5 seconds in the HomeSeer Speaker client. I am using Homeseer V3.
            This is very strange because the plugin does not do anything with speech.
            I will take another look and see if anything jumps out at me
            Cheers,
            Bob
              I emailed Rich about this. Here is his response:
              "That is not an error, vr has to be rebuilt if a device changes name or location or an event is created or deleted"
              So this would happen in any plugin that changed the name of a device, which would happen in BLLAN if you renamed one of the computers in the plugin.
              Cheers,
              Bob
                Re: error in speaker client
                So rebuilding of vr does not happen automatically?
                Sent from my GT-P1000 using Tapatalk 2
                Transitioning to HS3Pro .298 - WinXPEmbedded
                Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
                  No idea how it works. Rich just let me know that those are normal. Remember that it is still beta
                  Cheers,
                  Bob
                    Thank for looking into it.. I disabled BLLAN now and wait for the next beta release of homeseer to try again.
                      I applied .18 patch and this fixed the issue.
