Rebuilding VR Commands
  • Rebuilding VR Commands
    I've just installed BLLAN 2.0.9.0 in HS3 .42 and the Speaker client is now issues "Rebuilding VR Commands...." every 5 seconds.
    Is there a way to clear this up, I am not using any VR commands.
    HS3 rebuilds the VR command set every time the device names are changed, it appears to be pushed at each cycle, which would explain it.
    I have no idea why this happens. I see it here too.
    Cheers,
    Bob
      Bob,
      I see the same issue here too. Even up to almost unresponsiveness or spontanious exits of the speakerclient. Disabling BLLAN solves it for me.
      Could this be caused by the fact that you tried to update the online/offline image trough the device imagesinstat of graphic pairs? Online and offline images do not work at all for me. The last I do not really mind, but speaker client being slow is becoming an issue for me?
      Wim
      -- Wim
        I have never seen the slowdown here.
        I will have another look and let you know
        Cheers,
        Bob
          Bob,
          I see the slowdown after three days of running. Opening speech client from the task bas is then lagging. Also speach is taking some lags here. With a fresh start speech is immediate, after a whil it takes a few seconds.
          I had three time speaker clients disappearing from the task bar - cannot blame BLLAN for that as I do not know why this happened, I only know speakerclient is rebuilding VR every 3 or 4 seconds.
          Wim
          -- Wim
            It is weird because BLLAN does not use the VR at all.
            Cheers,
            Bob
              Bob,
              I understand. But HS rebuilds VR when a Device changes on the core data. As you update the device image, I think HS is retriggering the VR rebuild? If you'd change that part back into graphic value pairs, I think the rebuild would not be triggered anymore for HS.
              But that is still guessing with a bit of knowledge. If I change the device image on other devices I also see the rebuild triggered here. That is why I am guessing your plugin is setting the device image on every check?
              Wim
              -- Wim
                OK I will look
                Cheers,
                Bob
                  Try 2.0.10 in the HS3 updater
                  It no longer updates the device image property just the device string.
                  Cheers,
                  Bob
                    Bob,
                    It is looking good now after the first start, speakor log has been quiet for some timenow, so I think we got the nail
                    Thanks a lot, and I hope to see no more lagging for the speaker!
                    Wim
                    -- Wim
                      No problem
                      Cheers,
                      Bob
