ASUS AC66U Support
  • ASUS AC66U Support
    can you supply the driver to support the above router ?
    Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro
    You will need to download the Router Logger app from my site and run it with your router in order to get some of the logging so I can see the format
    http://bladeplugins.no-ip.org/Downlo...p#RouterLogger
    Get it running and leave it running for a bit to capture some traffic
    Then email me the log from the app.
    Cheers,
    Bob
      installed .4, selected azus
      got this on config page
      any instructions on how to configure ?
      disregard wrong router .. forgot to hit save
        I also have the same ASUS Router AC66U with Tomato firmware. Is the router and tomato supported on the current release of BLRouterMonitor for HS3?
          Hi Blade, ComputerNerd -- I've got an ASUS with Tomato (Shibby's build). Just installed BLRouterMonitor and am attempting to set everything up. I've got SYSLOG sending to my HS3 server on port 514, but BLRouterMonitor doesn't seem to be picking up any router activity.
          Blade, would you need me to run something on my router to give you system information?
          Thanks!!!
          hjk
            I'm also running a router with tomato v1.28 by shibby although the hardware is netgear. Would love to get this plugin working with my router. Did this go anywhere? I can't seem to even get the router logger to capture anything.
            Attached is a screenshot of the logging page on the router firmware.
            help!!!
              I was able to capture a log file using syslog watcher. Not sure if this helps at all.
