This thread will be used specifically for Release notes for the MeiUnifi plug-in.
Versions
3.0.0.39 (BETA)
Added extra logging for the websocket connection
Added reconnect logic in case websocket is dropped.
Discussion here: https://forums.homeseer.com/forum/internet-or-network-related-plug-ins/internet-or-network-discussion/meiunifi-sirmeili/1458796-meiunifi-version-3-0-0-39-beta-is-now-available-real-time-unifi-notifications
3.0.0.36 (BETA)
Added websocket suport for network.
Client Tracking is now real time via Websockets for UnifiOS
Option to monitor Controller CPU is availaable again (UnifiOS)
Controller CPU monitor is real time.
Discussion here: https://forums.homeseer.com/forum/internet-or-network-related-plug-ins/internet-or-network-discussion/meiunifi-sirmeili/1456790-meiunifi-version-3-0-0-36-beta-is-now-available-real-time-unifi-notifications
3.0.0.35 (BETA)
fixed small deserialization bug when loading the cameras in the config screen.
Discussion here: https://forums.homeseer.com/forum/internet-or-network-related-plug-ins/internet-or-network-discussion/meiunifi-sirmeili/1455424-meiunifi-version-3-0-0-35-beta-is-now-available-real-time-unifi-notifications
3.0.0.34 (BETA)
REAL TIME notifications for UnifiProtect Camera Motion events (on UnifiOS)
REAL TIME notifications for UnifiProtect Doorbell Ring events (on UnifiOS)
Discussion here: https://forums.homeseer.com/forum/internet-or-network-related-plug-ins/internet-or-network-discussion/meiunifi-sirmeili/1455387-meiunifi-version-3-0-0-34-beta-is-now-available-real-time-unifi-notifications
3.0.0.33 (BETA)
final fix for actions in newest firmware of UnifiOs (block, Unblock, POE Port screen).
Discussion here: https://forums.homeseer.com/forum/internet-or-network-related-plug-ins/internet-or-network-discussion/meiunifi-sirmeili/1455311-meiunifi-version-3-0-0-33-beta-is-now-available
3.0.0.32 (BETA)
Fixed Breaking Unifi change for CloudKeys being updated to UnifiOs (See this thread: https://forums.homeseer.com/forum/in...t-start-up-now)
Discussion here: https://forums.homeseer.com/forum/in...-now-available
3.0.0.30 (BETA)
Fixed bug with device and client commands not working since adding Dream Machine Prod support.
3.0.0.21 (BETA)
Added support for Dream Machines.
Cleaned up some code.
Discussion here: https://forums.homeseer.com/forum/internet-or-network-related-plug-ins/internet-or-network-discussion/meiunifi-sirmeili/1415689-meiunifi-version-3-0-0-21-beta-is-now-available
3.0.0.20 (BETA)
Added Cloud Key Temp and CPU Monitoring.
WARNING: Use this feature at your own risk. As far as I'm aware, you have to use "root" as the username and your admin password to access the Cloud Key management. I encrypt the password when storing, but that is the best I can do. Please use this at your own risk.
3.0.0.19 (BETA)
Generalized the device creation and lookup to only depend on the type, not the model. If the model is not found, it will use it's type to determine the type of device (Switch, phone, AP, or Gateway).
3.0.0.18 (BETA)
Added support for USC8P450 Unifi Industrial Switch
Fixed issue with Client Tracking and multiple controllers/sites. Note that this version will break events for client tracking.
Discussion here: https://forums.homeseer.com/forum/in...ease-candidate
3.0.0.17 (BETA)
Added support for UniFi AP-Flex-HD (UFLHD)
Added option to show "configured" devices on client tracking page (Devices that are enabled or were previously enabled)
Plugin now updates all client tracking devices with a new status when a a new Device (Ap, Switch, etc) is added.
Fixed bug where an unknown unifi device would stop HS devices from being updated.
3.0.0.16 (BETA)
Added support for USL16P and USMINI switches.
3.0.0.15 (BETA)
Fixed issue with WAN IP being enabled can cause other devices to not update. Please check this post for manual steps to rectify after installing this version: https://forums.homeseer.com/forum/in...86#post1380486
Fixed issue where checking a client to track and unchecking it, would mean that you could no longer enable it. This should be fixed (Even for existing setups. No manual steps needed)
3.0.0.13 (BETA)
Should automatically try and log back in if the controller is restarted (it may take 1 polling cycle after the controller is back up to log back in)
Fixed issue with internat capacity string not being reset when it's back under 100%
3.0.0.12 (BETA)
Fixed serialization issue with USGs with Temps
Accounting for Internet Capacity over 100%. Adding string to status string to check Unifi Configs
Fixed second serialization with USGs with Temps
3.0.0.10 (BETA)
Added extra logging around temperature updates for USGs
Fixed Temp device image for 10-19 to point to correct image.
Discussion here: https://forums.homeseer.com/forum/in...efore-updating
3.0.0.9 (BETA)
Added temp devices for certain USG devices which support them (untested) ( )
3.0.0.8 (BETA)
Attempted fix for new alpha version of Unifi Controller
Fixed Multiple WAN IP devices in the configs having the same number (1)
3.0.0.7 (BETA)
Added passthrough status on POE Devices
Displaying port name instead of nubmer on POE port config page.
Added option on client actions event action to select a device or add by mac address
Added option for multiple WAN statuses
3.0.0.6 (BETA)
Added debugging to settings update code
only attempting to fix the controller device deviceType if the device exists. Logging a warning if it's missing.
3.0.0.5 (BETA)
Storing Enabled value for POE Devices and Client tracking devices and retaining device reference.
Updating client tracking devices when adding new site devices (APs/Switches/USGs)
Fixed Controller Device type
3.0.0.4 (BETA)
Added check that POE port is using power before attempting a restart
fixed issue with poe port config page outputting multiple dropdowns for switches
fixed issue with client track devices not always updating correctly.
Added debugging around setting Client Tracking device value.
3.0.0.3 (BETA)
Added POE Port devices. See Plugins -> MeiUniFi -> Port Device Config
POE Port devices show the mode of the Port (Off, 24v Passive, Auto/POE+)
Fixed Clients not saving the device reference to the config when first creating them (they were saved only after the first update of the status value)
Fixed a bug that might have prevented creating client tracking devices with the proper address.
Added menu to the top of the config screens
Added a link to the forums in the Plugins menu and on the top of the config screens.
Refactored a little.
3.0.0.2 (BETA)
Changed address for Client Tracking devices to be appended with a value to prevent UltraMon from updating the device strings
3.0.0.1 (BETA)
Added filter on name on client tracking page ( vasrc )
Default controller and site on forms to last selected values (Saved in settings) ( vasrc )
Moved USG specific device options to the USG device in the Unifi Device Config ( vasrc )
Added option to Disable a site.
Refresh devices status after an action is committed to make it appear more responsive ( Eman )
3.0.0.0
Initial Release
Versions
3.0.0.39 (BETA)
3.0.0.36 (BETA)
3.0.0.35 (BETA)
3.0.0.34 (BETA)
3.0.0.33 (BETA)
3.0.0.32 (BETA)
3.0.0.30 (BETA)
3.0.0.21 (BETA)
3.0.0.20 (BETA)
3.0.0.19 (BETA)
3.0.0.18 (BETA)
3.0.0.17 (BETA)
3.0.0.16 (BETA)
3.0.0.15 (BETA)
3.0.0.13 (BETA)
3.0.0.12 (BETA)
3.0.0.10 (BETA)
3.0.0.9 (BETA)
3.0.0.8 (BETA)
3.0.0.7 (BETA)
3.0.0.6 (BETA)
3.0.0.5 (BETA)
3.0.0.4 (BETA)
3.0.0.3 (BETA)
3.0.0.2 (BETA)
3.0.0.1 (BETA)
3.0.0.0
Initial Release
