MeiUnifi version 3.0.0.12 Beta is now available! (Release Candidate)
  • #16
    Originally posted by John245 View Post
    I did that of course.
    New try also deleted the logs.
    Still no luck.
    John
    With a new install the previous USG settings for temperature are reset, so you go back in there and manually set "has got temperature" to true
    then you will get the option again.
    Don't forget to reboot the controller and USG....etc
    Eman.
    The Closer.
    • #17
      Eman.
      Did some more testing.
      Reboot everything did not help.
      Disabling WAN 1 IP did start updating the temperatures of the USG Pro.
      WAN 1 IP has also the non valid value of 0.
      John
      • #18
        John
        I had a similar issue when upgrading from 3.0.0.10. I tried numerous reinstalls and everything else I could think of. I finally rolled back to 3.0.0.0 (production version) and then upgraded to 3.0.0.12 and everything began working normally again.
        --Barry
        • #19
          --Barry
          sirmeili
          Do you have the initial production version available. Or are you working on a bug fix. See also https://forums.homeseer.com/forum/in...6-and-meiunifi
          John
          • #20
            sirmeili
            John
            It's in the Homeseer updater, under the "Internet and Network" category.
            --Barry
            • #21
              --Barry
              Thnx,
              But this does not solve my issue.
              Although the WAN IP is not the most important I would apreciate it if it can be fixed.
              John
              • #22
                Sorry all. Work has been a bear and I'm working a lot. Can you turn on Debug Logging and let it run for a while and send me the logs?
                Frank
