Ubiquiti setup suggestions
  • Ubiquiti setup suggestions
    Hello,
    I’m getting closer to switching over to all Ubiquiti equipment and wanted to get some feedback from everyone. I already have the UniFi APs throughout the house so now I’m just looking to replace my all in one Modem/Router.
    The equipment that is currently on my list is:
    Netgear Cable Modem CM1000 - Currently 300X20 but may upgrade internet
    UniFi Security Gateway Pro
    UbiQuiti Edgeswitch 24 GB RJ45 Ports (not POE)
    1) Do I need to replace my Netgear 16 port managed switch with the Edge switch? What would be the advantage? It would be a $200 savings without it.
    The current setup is a modem/router that feeds into the 16 port switch and then network cable goes throughout the house. Only a couple of computers including the HS computer are wired as well as the APs, TVs, Z-Nets, other than that, most everything else is wireless including all IP Cameras.
    With the way our house is structured, it is really difficult to string wire to more places around the house, thus the WiFi cameras. And I have POE injectors on each AP as there are things like the Z-Nets plugged into the same port (5 port switch) so I would lose the power anyway. Unless I forked out more for a multi port POE that I would just have one thing powered, wouldn’t make sense.
    What are your thoughts?
    Thank you everyone!
    HS3 3.0.0.500 &HSTouch Designer 3.0.71 with 782 Devices, 479 Events
    Plugin's:
    BLBackup, BLOccupied, BLShutdown, EasyTrigger, Ecobee,
    weatherXML, Jon00 Alexa Helper, Network Monitor, Z-Wave 3.0.1.252
    Since you're going with a combination of unifi and edge, you won't get benefit of a single controller interface so you don't have that reason to swap out the 16 port switch. I went 100% unifi to streamline configuration and monitoring, and for HS3 integration although that's pretty much just PoE control and temp monitoring for the switches. As long as it gives you the configuration options you need--vlan tagging etc--then I don't see why you'd need to swap it.
    -Wade
      Ok, didn’t realize the Edge wasn’t UniFi, with the UbiQuiti name in front of it I assumed it was. What advantages would a UniFi switch add? It would obviously add POE (haven’t found one that doesn’t have POE yet) but is there more?
      Thank you
      Plugin's:
        The first couple minutes of this video give some basic differences. https://www.youtube.com/watch?v=1RmowhoGr4c
        Google ubiquiti edge vs unifi and you'll find more info.
        -Wade
          With all UniFi equipment, then the info shown on the dashboard is complete. If you don’t need this info, then no reason to buy a new switch.
          Michael
          HS3 Pro 3.0.0.470 | 849 devices | 349 events | OpenSprinkler | BLShutdown | EasyTrigger | NetCAM | Harmony Hub | Sonos | SDJ-Health | BLUPS | PHLocation | BLBackup | BLLock | Z-Wave 3.0.1.243 | weatherXML | Pushover 3P | Blue-Iris | AirPlaySpeak
            I don't believe anyone made mention that another difference between UniFi equipment and Edge equipment is that Edge requires you to know CLI (unix based) whereas UniFi has more polished admin user setup menus and drop downs (you can also use CLI if you want or need to) as @Michael stated if you use all UniFi equipment you will have slick information Panels available whereas those equipment's that are not UniFi will not be sharing their status and will have to be view by some other means via SSH or something else. Now if your a power user and know CLI then Edge is the way to go. Personally I did not know much about setting up a total system but with UniFi I was up and running in a matter of a few hours by watching a few good Utube videos, MTC Mike
            Computer: CUK Intel NUC7i7BNH
            Op System: Windows 10 Pro - Work Station
            HS Version: HS3 Pro Edition 3.0.0.435
            Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
              Will a managed UniFi switch improve latency?
              Plugin's:
                I don’t know. I’ve been around computers since 1978 but I am no where near being an expert. I went with UniFi after reading various posts including those by rprade. I also figured that unified equipment would work better together than disparate equipment. Thus the word UniFi?
                Our iPhones are on an always on VPN connected to our home network. This means we have no forwarded ports yet have access to Blue Iris notifications. Another added bonus is that since we are on a VPN, our iPhone browsing is secure and “originates” from our home IP address.
                Bottom line one for us is that this is the best and fastest network we’ve ever had. Here is a screenshot of my iPad Air (older) WiFi speed:
                Our speed at the modem is rated at 400/20 and we get around 450/20 from a wired computer. I’m always trying to optimize our network so our speeds may improve in the future for our WiFi clients.
                Michael
                  For most use case UniFi will do the job and do it very well. Unless you have complex routing or require Layer 3 routing, go UniFi as an end to end solution.
                  I on the other hand use Edge except for a few UniFi Access Points and Cameras. The UI for Edge Switches and Router have developed significantly and most things are available through the UI and do not require CLI. Edge combined with UNMS is moving closer to UniFi WRT system management.
                    I appreciate all the feedback! After watching the video that Wade posted, I'm thinking that I won't need the switch right away but in order to setup VLANs I would need one? VLANs are an extra layer of security that you can segregate LoT devices, HS box, etc into, if I understand that correctly?
                    Rvtravlr I noticed next to the AP image in your screenshot that it shows two different data rates (31Mbps & 1.95Mbps), have you set up a data bandwidth limitation or is that just the bandwidth being used at that point in time? Also, the download on your iPad is 128 with 400 max, is it at 128Mbps due to the VPN that you have setup, the particular server that you used to test?
                    brientim I agree, and plan to stick with all UniFi equipment. My main goal is to have better network security and to have the equipment to learn with.
                    Plugin's:
                      VLANS allow you to segregate IoT devices, etc. I haven't moved my cameras to a seperate VLAN because it's my understanding, from reading various forums, that there would be a performance hit with Blue Iris.
                      Current bandwidth is displayed.
                      128 Mbps on my older iPad is quite good in my opinion. There is no limit set.
                      We haven't seen any perceptible hit by using an always on VPN. Makes it easy for my wife - she just uses her phone as she would normally.
                      Michael
                        The data rates shown are from the APs to the USG (upload to network) and from the APs to the clients (download from network).
                        Here I am watching YouTube on my phone
                        And here I have stopped
                        note that the data rate to the clients has dropped.
                        I also have to say that my move to a full UniFi system has yielded stellar reliability, speed and stability. It was expensive, but every niggling problem I had with a mishmash of POE switches, router and access points has disappeared.
                        Randy Prade
                        Aurora, CO
                        Prades.net
                          I can ditto Randy's finishing statement, Like @Michael after reading some of Randy's posting re UniFi I too took the plunge "into the Black!" and have been happy with my setup ever since, obviously this wasn't your original enquiry to have the ability to run existing (non Unifi, e.g switches) with Unifi equipment's (e.g. APs) should work well together until you decide to upgrade at some latter date. Mike
