Not sure if it's just an error with the plugin or with the controller. And not sure where to look.
Warning status on four of six devices - what's causing the warning?
Well... that's weird AF. I removed all devices and killed the config and restarted the plugin. Then re-added devices one at a time in the plugin config. They'd show up bad initially - even the WiFi Score showed zero / poor. Then I disable the device in the plugin config, remove the HS device and enable the plugin device again... and it's correct. WiFi score of 92%, for example. But if I don't do this, it doesn't seem to update those HS devices correctly?
Hm. Okay. Some devices update on their own at the next poll... some don't seem to. But the delete / re-check seems to work.
Another thing that seems worth doing: the default setting per HS device of "Do not update device last change time if device value does not change" being disabled gives a better indication of updates. Seems valuable since many HS devices value doesn't change - just the status. So that gives me an indication of the last time the plugin updated that HS device.
