Just thought I'd share my use of this plugin. I wanted to add some bling to my rack and stumbled across this plugin that meant it saved me a ton of time messing with API's. Keeping things simple I created the dashboard using HSTouch. The screen is a touch screen connected via HDMI to a computer below running the HSTouch client. Just a cheap touch screen and cut a hole out of a blank rack panel to fit.
Rack Bling
ShimmerNZ mmGreetings fellow Kiwi. Where did you get the touchscreen from?iCore5 Win 10 Pro x64 SSD
HS3 Pro Edition 3.0.0.435 Windows
BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
https://www.aliexpress.com/item/4000...533c4c4d6heNo2
Originally posted by sirmeili View PostAre you pulling the top values from the API yourself? If so I can look at adding them to the plugin.
Originally posted by sirmeili View PostOMG I love it! I wish HSTouch projects were more shareable! I'm about to move to a glass front rack in my office and I wanted to do a dashboard behind the smoked glass. this would be perfect!Attached Files
- Likes 1
Originally posted by ShimmerNZ View Post
Project and graphics attached. The Unifi folder drops into your skins folder. Obviously a bit of work to tie everything to your own devices but if it help someone then here it is.
And I thought about the device count and I can actually pull it, but trying to determine the best way to store it. I was thinking 1 device for total and 1 for "missing", but then thought that the way you have it might actually be best. Not sure. How would you want that data stored? 2 devices per type?
