I recently purchased a Cloud Key to upgrade from my existing setup using a PC to run the controller software.
Since my upgrade, the plugin is broken. I have tried to configure the plugin using Controller Config and CloudKey Config.
I set up a local user with the username "root" and a password and tried that and still nothing.
I am seeing the following in my log - to be clear I have credentials entered both under the Controller Config tab and the CloudKey Config tab:
Posting back to plugin web page CloudKey_Config: Error parsing NaN value. Path '', line 1, position 1.-> Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
Any thoughts on what I should be doing differently?
