Initial Release.
    Initial Release.
    Hi All,
    I have just released the SNMP Monitor plugin, This plugin will alllow monitoring of SNMP devices within your network, Currently it will support V1 and V2 devices.
    You can import MIB files to work out the OID's that you wish to Monitor and also do SNMP walk operations to check a device.
    If you encounter a MIB file that cannot be read (Some Company's do not stick to the Standard MIB spec) Please let me know.
    Happy to address any problems or look at any suggestions, Just either flick me a private message, or drop a note in here.
    Mat
    The file I got ends with gz. how do I make it into a mib file. I have the oid i need but i cant get plugin to take it
      Hi Rdc,
      I can see from my messages you are having a few issues (Particularly with CPU usage) So i will get onto that now, Has a couple of family medical issues lately so have not got back to it...
      For the MIB file, i am not sure the difference to the gz file, so if you can send it over or post it here i can have a look see.
      Mat
        Cant upload a gz file but dont really need it anymore. Just need the plugin to work correctly so I can use it. I have all the devices ready to monitor but plugin must remain off to prevent HS4 from crashing.
          Turned plugin on for a few minutes but not all devices refresh even though all are set to 30 seconds
            Hi Rdc,
            I have just release Beta 1.0.0.1 can you please install that, It should take care of the Excess CPU usage issue.
            For the second problem, we will have to do a bit more debugging, Can you install the Beta, then re-try if the issue is still there let me know and we can work through it.
            Thanks for the patience and support.
            Mat.
              The cpu useage is good but the devices do not refresh every 30 seconds as i showed you above
                Hi rdc,
                Good to hear on the CPU usage, So looking at the above its working as expected, the Time will only update if the Value changes...
                I can add a setting in the config to update the time regardless if that will suit?
                Mat
                  That sounds great thanks
                    Hi Rdc,
                    I have just released Beta 1.0.0.2 which has a button on the config to enable time updates even if the value doesn't change. Let me know how that goes.
                    Mat
                      That works. Thanks
                        Hi Rdc,
                        Thanks for confirming, Please let me know if you have any more trouble or suggetions.
                        Thanks for the support.
                        Mat
