value instead of string in device
    Hi Mat,
    I'm just testing your plugin and I wonder if it's possible the SNMP get could fill the value if the index is an integer.
    This way we can create triggers based on the device value.
    -edit-
    Also do you have some documentation for this PI?
    I've uploaded a MIB file and now there is a file in my temp directory. But I have no idea what to do with it.
    Hi Alan_Smithee,
    Apologies for the delay, I must have missed a notification email.
    Ok, so 2 parts.
    First one, So what i think you asking is if the plugin could walk the rest of the OID to find all possible index's? If that is the case, then I believe i could get that to work. Please let me know if that is what your after,
    Second part,
    Here is the Documentation :
    SNMP Plugin for Homeseer 3.pdf
    The MIB upload works in 2 parts, First it saves the file and reads all the OID's. then you will be able to view the MIB file which allows you to select the OID's to add to the monitoring.
    Its detailed in the Guide, So if its not working as expected please let me know and upload the MIB your trying to use and i will fix it for you.
    MIB's are a bit all over the shop, I believe the plugin should cope with most it encounters as i tested a fair few random ones, but while i was developing it took a while to get some working as the nested structure is not always perfect in some files.
    In any case, let me know if you have issues and ill fix them.
    Thanks for the feedback, Please let me know how you go.
    Mat
