If this is your first visit, be sure to check out the FAQ. You must register before you can post. Your first post will be checked for appropriate content
(SPAM) - please allow a bit of time for that. After that, you'll be able to post at will!
With UltraMon on HS2, I was able to monitor the status of devices on the VPN tunnels attached to the local network where the HS2 server was resident. This doesn't seem to work on HS3. I can mark the devices as enabled, but this setting disappears. Was this a deliberate change, or am I am doing something wrong?
