HS2 Standard 2.2.0.11
Windows Server 2003 R2 Enterprise Edition
I just downloaded and installed UltraMon. When I go to Setup/Interfaces/Config I get the following error:
System.NullReferenceException: Object variable or With block variable not set. Server stack trace: at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ct or(Object Instance) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at Scheduler.hsapplication.Plugin(String pi_name) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateP rocessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.PrivatePr ocessMessage(RuntimeMethodHandle md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProce ssMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext) Exception rethrown at [0]: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.Inv okeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at ASP.hspi_ultramon_hspi_ultramon_aspx.Page_Load(Object sender, EventArgs e) in C:\Program Files\HomeSeer\html\hspi_ultramon\hspi_ultramon.aspx:line 31
I see it discovering devices in the log file:
<TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGDateTime1 noWrap align=left>8/3/2007 11:52:58 PM </TD><TD class=LOGType1 align=left colSpan=3>UltraMon Warning </TD><TD class=LOGEntry1 align=left colSpan=8>Discovered new host 192.168.1.100 on 192.168.1.0/24</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>8/3/2007 11:52:59 PM </TD><TD class=LOGType0 align=left colSpan=3>UltraMon Warning </TD><TD class=LOGEntry0 align=left colSpan=8>Discovered new host 192.168.1.101 on 192.168.1.0/24</TD></TR></TBODY></TABLE>
But I'm not able to set it up and/or control it.
Any thoughts on what I can do to fix my problem? Thank you! Jim
