Failure to Save or Add a Discovered Device
    Plug-in has been working great, but when I tried to add another discovered device, the following error occurred:
    The following errors have been reported:
    • Failed to process selected discovered devices to an unhandled error.
    The log shows:
    7/4/2011 3:54:52 PM UltraMon Warning Unable to obtain free device code for 'BaseClass' ; Try restaring HomeSeer.
    Restarting Homeseer and/or rebooting the server has no effect. Before I did anything else, wanted to see if there is any experience with this or whether any other information might be useful.
    The log shows:
    Still struggling with this and no resolution. Any help out there?
      How many devices have you created so far?
        There are 61 so far.
          What is the device code for the last device created?
            Assuming these are assigned in sequential order, the last seems to be `64
              I see a similar issue in another post: http://board.homeseer.com/showthread.php?p=965111
                I guess you already figured out or knew there was a device limit. I removed a device and then was able to successfuly add the new device. Did I miss this in the documentation? Let me know if there can be a resolution to add additional devices. Thanks!
                  64 device limit
                  I seem to be having the same problem.
                  Philip
                  pabbott@cpak.com
                    Ultra -- just curious. Are you planning to do anything about this limitation? Thanks.
                      Sorry, I was on vacation last week. I found and corrected the issue and will post the fix within the next hour.
                      Regards,
                      Ultrajones
                        Vacations are good, and so is the fix you provided. Thanks!
