The outside monitoring is how I determine if my internet connection goes down. I have 4 websites being monitored. If all 4 are off line I trigger an event that sets my device "Internet Connection" to off. This controls all my events that need internet access like TV listings download or weather downloads. If even one of the 4 monitors come back online than the internet connection is set to on.
For Internet monitoring, I was thinking about adding a textarea (similar to the IP subnets) that allows you to specify from 0 to n IP addresses. Those IP addresses would be checked via ICMP ping, then I would update 2 HomeSeer devices to indicate an overall Internet health status. The first HomeSeer device would indicate the percentage of the number of devices that are online (so a device value from 0 to 100). The second device would track packet loss percentage (again, a device value from 0 to 100). Thoughts?
When my internet goes down, I usually can no longer ping my actual cable modem which happens to be at 192.168.100.1 (most are). I do not see any way I can monitor my cable modem using UltraMon3 anymore. It would also be nice to be able to ping my DNS servers as well. Also, does the built in email notification function of ultramon3 use ultrasmtp3 if it's installed? It'd be nice to get delivery failure notices. I'd also like to throw in my vote for the return of TCP port monitoring. Thanks
SNMP Trap receiver on UltraLog3 would be great. I say UltraLog3 because it already has syslog monitoring so it'd make sense to put it there. That said, I have a managed Cisco Switch with PoE and made a script to ping every ip on the subnet, query the switch port # and get the POE power consumption via SNMP. It'd be nice to add something like that to ultramon.
Multiple controls with the same ID 'imgDeviceTroubled' were found. FindControl requires that controls have unique IDs.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: Multiple controls with the same ID 'imgDeviceTroubled' were found. FindControl requires that controls have unique IDs.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HttpException (0x80004005): Multiple controls with the same ID 'imgDeviceTroubled' were found. FindControl requires that controls have unique IDs.]
System.Web.UI.Control.FillNamedControlsTable(Control namingContainer, ControlCollection controls) +258
System.Web.UI.Control.FillNamedControlsTable(Control namingContainer, ControlCollection controls) +316
System.Web.UI.Control.FindControl(String id, Int32 pathOffset) +258
System.Web.UI.Control.FindControl(String id, Int32 pathOffset) +468
System.Web.UI.Page.FindControl(String id) +43
System.Web.UI.Page.ProcessPostData(NameValueCollection postData, Boolean fBeforeLoad) +210
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2254
Source Error:
Stack Trace:
Thank you for reporting this bug. It is resolved as of UltraMon3 HSPI version 3.0.5139.27671.
Sorry, I missed this when you posted it. That sounds like it would work.
I could add a condition to an event that if the IP addresses % is > 0 then my connection is up.
Would it be possible to enter an IP:Port to monitor an email server?
Jeff Farmer
HS 3, HSPhone
