UltraMon3 (Network Monitor) For HomeSeer3
This is a sticky topic.
    #46
    TCP port monitoring and the ability to monitoring anything outside of the local subnet has been removed from UltraMon3. I have not decided if I'll be adding either feature to UltraMon3. I guess I'll see what type of demand there is for those 2 features.
    Originally posted by sparkman View Post
    In progress of slowly migrating to HS3. I've used the HS2 plugin for a number of years and those two features were the prime reasons I was using the plugin. Any chance of adding them into the HS3 plugin?
    I've been running the HS3 version of the plugin in trial mode and need to decide in the next couple of days as to whether I will purchase it. Can you confirm if these features will (or won't) be added?
    Al
      #47
      Ultramon multi subnet issue
      I ma having a problem when adding multiple subnets to the list of monitored subnets.
      I've used the following syntax i.e. 10.10.10.0/24 all is fine when I have single subnet, when I add say 10.10.10.11.0/24 I can not see the devices under the Devices TAB of the first subnet. When I enter just the 10.10.10.0 I no longer can access the Plugin configuration. Any ideas?
      Cheers
      Mark
        #48
        Cheers
        Mark
        What subnets are you trying to monitor? 10.10.10.0/24 is valid, 10.10.10.11.0/24 isn't valid and 10.10.10.0 is a single address.
          #49
          I am trying to monitor all ip's on the following subnets:
          10.10.1.0 host range 1-255
          10.10.2.0 host range 1-255
          10.10.3.0 host range 1-255
          Also the point I was trying to make with entering single address of say: 10.10.1.0 after restarting the HS the plugin configuration options are no longer accessable. You need to delete the config files and restart the HS again to get back in.
          Another item that I am having problem with is that if the system was registered on one IP then assigend to another MAC then I then have two IPs showing under the IP TAB for the same device old and new. Even though there is no conenction anymore on the first IP. Can you tell me how I can clean this up please.
          Mark
            #50
            Any ideas on how to address this?
            Mark
              #51
              Mark
              UltraMon3 HSPI was designed to monitor home networks of around 255 devices. While UltraMon3 HSPI supports monitoring multiple subnets, you may experience delays in detecting hosts when scanning for 700+ IP addresses.
              You'll enter the following subnets:
              10.0.1.0/24
              10.0.2.0/24
              10.0.3.0/24
              Then restart HomeSeer.
              At this point, I don't think the plug-in checks the subnet to clean up the other IP address is may have occupied in the past. I'll have to add code to do that.
              Ultrajones
                #52
                Thanks Ultrajones. I did try doing this with just two subnets:
                10.10.1.0/24
                10.10.2.0/24
                however when I select the IP Subnets tab I can then only see the IPs on the 10.10.2.0 subnet and there is an error when I try to select the 10.10.1.0 subnet.
                Any idea how to resolve this?
                Regards
                Mark
                  #53
                  10.10.1.0/24
                  10.10.2.0/24
                  Regards
                  Mark
                  Any Suggestions?????
                    #54
                    I cannot duplicate the issue you are reporting. Please try shutting down HomeSeer, then rename (or remove) the following files, then restart HomeSeer.
                    HomeSeer HS3\Data\ultramon3\ultramon3.db3
                    HomeSeer HS3\Data\ultramon3\ultramon3.xml
                    Ultrajones
                      #55
                      I'm having trouble with ALL IPs showing up! Then the log fills with "device address cannot be found" reports, as it apparently continues to ping something.....
                      Screenshots attached....
                      Enabled Plug-Ins:
                        #56
                        I had that too. The only way I could clear this is by deleting the DB. But this is definitely not the right solution.
                          #57
                          I have already tried that....
                          Enabled Plug-Ins:
                            #58
                            Interesting. That may be a bug. Let me look into this a bit more.
                              #59
                              Can you look at the Device Management page, then filter on device type "Type: Plug-in: UltraMon3", then tell me if any of the devices have an empty "Address" field?
                              Ultrajones
                                #60
                                This looked a little weird, too......
                                Enabled Plug-Ins:
