Out of base codes
OK, I moved some other devices for another plugin that I was then able to fake out easier, so you plugin was able to find an open code, but it might still be useful for someone else to know if there is another workaround.
Out of base codes
I am out of base codes, but could use an open letter that is not in use for the base code. I tried to copy the normal BaseCode_BaseClass section from another one of your plugins, setting the value to an open letter I have, and restarting, but this did not help. I still get the log file error. Does this plugin use a different label in the ini file, or can I otherwise fake it? I have used this method on one other plugin where I was also out of base codes, and it worked. I am hoping I can do so with this one as well. My HS is too big!Tags: None
