Not sure when this started happening, but now I no longer have a checkbox available to create a device (the action column) nor do I see the ping history... I did just update to HS 3 .147 and the latest Ultramon...
Headers "missing", no ability to create device?
Thanks for the quick replies - I have tried 2 different machines (a Mac using Safari and Chrome, a Windows 7 running IE 11 and Chrome 39.0.2171.71)
I cleared the cache on all those browsers, machines - I even deleted everything UltraMon in every directory I could think of and reinstalled the plugin - same thing...
Thank you for reporting this. It looks like older browsers are less forgiving with JavaScript syntax. The issue you reported should be resolved (tested with IE 10 on Windows 7 Pro). Please re-install the latest version and confirm it's now working.
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
I am guessing your browser was happy to give you the same file you previously downloaded. Please download the attached zip and place the 3 JavaScript files into HomeSeer HS3\html\hspi_ultramon3\js. You'll then need to clear your browser's cache.
UltrajonesAttached FilesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Hi Folks,
This is what happens when I have multiple subnets. The page works fine on the primary subnet that had been defined (top of the list in Monitored Subnet: first graphic)
When I select another subnet from the menu I get exactly as shown in the previous posts (second graphic 10.10.1.0). When I go back to the primary subnet by selecting it in the Monitored subnets the issue repeats (graphic three 10.10.2.0).
The only way to get back proper view is to click on any other Tab first then IP Subnets. But this only works for primary subnet (top subnet in the Subnet Monitoring Options)
Windows 8.1
HS3 Version HS3 Pro Edition 3.0.0.96
UltraMon3 3.0.5450.37284
I've also included the Subnet Monitoring Options config page.
See belowLast edited by marekd1; December 8, 2014, 07:48 PM.
Windows 8.1
See below
