UltraMon3 suspend not working - diags?
  • Ultrajones
    Yes, check the Windows event logs. If a packet is received, you'll see it in the Windows event viewer.
    The UltraMon Shutdown service listens on UDP port 9190. I found I had to add a firewall rule on my Windows systems to allow inbound UDP port 9190 on the local network.
    Regards,
    Ultrajones
  • gregoryx
    started a topic UltraMon3 suspend not working - diags?
    I've installed the Ultramon Shutdown Service and it shows as "running" in services.
    The HS logs show the command sent successfully.
    UltraMonService Suspend packet was successfully sent from 192.168.253.194 to 192.168.253.160 [485B3910800C]
    And WOL works as expected.
    Not sure where to be looking for the diagnostics. In logs on the remote PC? Where?
