UltraMonShutdown - lock and logoff not working?
    I cannot get the lock and logoff device actions to work on a Windows 7 PC associated with the device. The reboot and suspend work fine. Is this is an issue with UltraMonShutdown or a configuration problem?
    What version of UltraMonShutdown are you running on your Windows 7 system?
    Ultrajones
      Ultrajones
      I am using UltraMonHSPIServiceSetup version 1.2.2
        HAve you been able to reproduce this?
          No, I don't have a Windows 7 system to test right now. However, you should be able to check the Windows event log to see if the command was received and what command was run. Can you check the event log to confirm the command was run?
          Ultrajones
            Yes there is an event in te WIndows event log. See the two screenshots for the Lock event
              resolution?
              I know that this is a very old thread however I was wondering if there is a resolution to this? I have Windows 10 and the same thing is happening. I can see that the computer received the command in the Windows log but nothing happens.
                The Microsoft API methods I was using to lock the screen don't appear to work in all versions of Windows. I have been unsuccessful in getting it to work reliably between Windows versions.
                  thank you for your reply. Might you consider rewriting the API to work with Windows 10? everyone should be on that version now.
