Getting UltraMonShutdown working
    I get the following message in my log when I try to use the shutdown/hibernate/logoff commands.
    Sep-02 12:21:23 PM Error Unable to send Shutdown to device A4-BA-DB-EB-32-1E.
    Sep-02 12:16:01 PM Error Unable to send Logoff to device A4-BA-DB-EB-32-1E.
    I have the Ultramon service installed and running on the computer I am targeting and selected in the options of the plugin. Both my HS3 and the target computer are running windows 10.
    I am sure I have made some sort of error or have omitted some easy step in getting this set up, but I can't figure out what I have done wrong nor have I been able to find any instructions on getting this element of the plugin working.
    Any help would be appreciated
    Yes I have the same thing...can't help but think its firewall or something. I am Windows 10.
      ok. So i have picked this up again and want to get the shutdown service working.
      I am no longer getting an error type message, when I check my log, I get the messages that seem to say that the packets were successfully sent. The problem is that nothing happens to the computer that I am trying to logoff or shut down etc...
      I'm running windows 10.
      Oct-15 4:55:27 PM Informational WOL packet was successfully sent to 192.168.0.101 [A4-BA-DB-EB-32-1E]
      Oct-15 4:55:02 PM Informational UltraMonService Lock packet was successfully sent from 192.168.0.11 to 192.168.0.101 [A4BADBEB321E]
      Oct-15 4:50:37 PM Informational UltraMonService Logoff packet was successfully sent from 192.168.0.11 to 192.168.0.101 [A4BADBEB321E]
        Bump.
        Anyone successfully get this plugin to shut down and start a computer? I'm using Windows 10. I've tried to use this on two separate computers
        Here is an example of what I see in my log when I send a reboot request
        May-05 3:19:16 PM Informational UltraMonService Reboot packet was successfully sent from 192.168.0.11 to 192.168.0.102 [00016C6FE8D3]
        I am using the ultramonshutdown option.
        Alternatively, anyone have another way through homeseer to shutdown and restart a computer? I'd like to shutdown my office computer at night based on certain events or triggers and then open it up when I wake up as well as when I go to work and come home.
        Disappointing since the shutdown and restart was the primary reason for purchasing this plugin.
          Mine works fine, but I had to add a firewall exception for UltraMonHSPIService.exe for each machine on which I installed it.
          Randy Prade
          Aurora, CO
          Prades.net
            I think that did the trick.
            Thanks!
              Thanks!
              How did you get the sending part to work. I am getting the "Unable to send Reboot to device" in the log. What did you do?
              F
