Hello EddDeDuck,
I am sorry to hear you are having trouble with my plug-in. After you hit the update button, do you see an errors being written to the "Create monitored device" dialog window? If the window closes after clicking Update, does the device you created now appear on the "Devices" tab?
Regards,
Ultrajones
[SUPPORT REQUEST] Won't add iPhone (x2 devices)
I am having issues getting either of my iPhones to get added as monitoring devices.
I can see them on the IP Subnet tab but whenever I edit them to add the "enabled" tag although it looks limit saves if I reload the page or navigate to another tab the device isn't saved. I've tried over a week + manually adding them and making sure their status is "online" not "troubled" etc however no joy.
I also looked in the logs and I can't see any errors that might help debug the issue. Can sometime help or suggest what I should do? Having them monitored is a key part of my automation plans.Tags: None
