A couple of questions
  • A couple of questions
    Does this plugin not make devices for the zones?
    How do you name the zones?
    Thank You
    Don
    Yes it should create devices once you add a Rain8Net to the plugin
    Cheers,
    Bob
      Yeah, but I can't find any devices. Would love to get this to work, as it is hotter than hell here. Suggestions?
      Sent from my XT1565 using Tapatalk
      Don
        I just deleted mine here and deleted all devices.
        I then added a Rain8 unit and selected the zones I wanted and the devices got created.
        Cheers,
        Bob
          Ok. If I understand correctly, you deleted the unit and recreated it? I'm not home but will try that when I do. Thanks.
          Don
            That did it. I don't know why I didn't think of that.
            Another question, not pressing, but curious... In the help file there is a scripting method called requeststatus. What does this do, if it doesn't return anything?
            Thanks again for your help.
            Don
              It causes the plugin to poll the status from the rain8 unit
              Not really needed but is there in case you want to use it
              Cheers,
              Bob
                Thanks for the explanation. I'm curious about the activities log. I think I have enabled it but when I go to that page it says that it isn't enabled.
                Operator error, I suspect. Is this the correct area to enable the log?
                Don
                  Bump
                  Don
                    Hmmm that does seem odd. I wonder why it thinks it is disabled.
                    I will have to check the code once I am home and see why it is showing disabled
                    Cheers,
                    Bob
                      blade. i deleted the units and added and got the zones, now i cant find the devices.
                      HS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
