new setup
  • new setup
    hey bob. setting up the program. i cant find how to name the zones... i have two units, which show up, and 8 zones each... but i cant find how to name each one. thanks
    HS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
    it found my two units but no zones... cant operate anything. what I need to do?
      What version of the plugin are you using? The latest build?
      Cheers,
      Bob
        latest build. and HS3 i deleted and added new units and the zones appeared.
          for setting program, do i need to set every zone individually?
            Yes, you click setup for a zone and set when you want it to water.
            You can create multiple schedules for a zone
            Cheers,
            Bob
              but i cant run all the zones automatically as one event.... i have to program each zone separately, right?>
                That is correct
                You have to configure each zone for the times you want them to run
                Hope this helps
                Cheers,
                Bob
                  yes thank you.
                    zone not turning off
                    set up good.
                    operation of all zones good.
                    when i ran my event, one zone did not turn off, but it didnt show up in the log or the status as "on" i had to trun oif manually. any clue for what to do?
                    and is the "limit" time in the set up a fail safe against a zone being on forever?
                    thanks
                      using 2.0.17.0
                        Will have to check on the limit time.
                        Capture a debug log of you running that event and let me know what zone is the issue
                        Cheers,
                        Bob
                          how best do that. i am logging.
                            In the plugin options page you can enable debug logging
                            Turn on debug logging and then run the event that is causing the issue. Once the issue is captured then turn off debug logging.
                            Attach the BLRain8Net-Detailed.log zipped
                            It is located in the HS3 root folder
                            Be sure to let me know which zone on which module did not turn off.
                            Cheers,
                            Bob
                              got it. will do tonight
