Devices keep getting removed.
  • Devices keep getting removed.
    My Rain8 units that I create keep getting removed. This seems to happen about every third restart of the homeseer system.
    I am away in Florida right now but try and capture this with debug logging turned on and attach the debug log here zipped
    I have converted a few plugins to use an XML instead of an INI for settings
    I will work on converting this one as well once I am back
    Cheers,
    Bob
      I can wait for you to update the xml files. I'll be on the look out for an updated version of the rain 8. Thanks...
        Hopefully I will have time this weekend
        Remind me on Friday please
        Cheers,
        Bob
          Hey Blade! Happy Friday! Here is your reminder... Hopefully you have a chance to update this weekend.
          Thanks!
            Try out 2.0.18 in the beta section of the updater
            Let me know how it goes
            Cheers,
            Bob
              Same Issue
              I am having the same problem. How do I download the 2.0.18 beta version?
                It is in the beta section of the HS3 updater
                Cheers,
                Bob
                  Download failed. I tried Firefox, Chrome and IE. Is there another way to get the file?
                    I just updated mine here thru the updater beta section and it worked fine
                    Cheers,
                    Bob
                      I am having the same problem and it happens every time I reboot the server or even just restart HomeSeer. When I go to the plug-in I see "There are no units configured in the plug-in." The devices are retained, so I add the unit back in, assign the com port and save it and it works again until a restart, at which point I have to repeat the process. This is a big problem for me! I'm running version 2.0.19.
                      Please help. Thanks.
                        Do they still exist in your hspi_BLRain8Net.ini file in the config folder?
                        Can you confirm that they still exist in the INI file after you shutdown HS3
                        Cheers,
                        Bob
                          That hspi_BLRain8Net.ini file doesn't exist in my system - either when the unit is added or not. I do however have the HSPI_BLRain8Net.exe.config file and the entry in the settings.ini file though.
                            Do you have a BLRain8Net.xml in the config folder?
                            Do they exist in there?
                            Cheers,
                            Bob
                              Yes, it is in the config folder however the last modification date is from about 3 weeks ago and I have definitely had to add the unit back in today.
