RequestStatus question
  • RequestStatus question
    I'm trouble-shooting a script and trying to use the RequestStatus Method.
    I have both log messages to HomeSeer and log messages from Rain8Net checked but see no activity when using this method.
    PHP Code:
    hs.PluginFunction("BLRain8Net""1""RequestStatus"Nothing
    Shouldn't I see the request and response in the log? I see both when using other commands.
    Also the valve devices aren't always faithfully reporting the true state of the valves.
    Don
    Can you capture a debug log of this and attach it zipped
    Cheers,
    Bob
      Here you go. I turned off two stations and then requested status.
      Don
        I do not see a call to RequestStatus in the log so I will need to take a look at the code and let you know
        Can u log this as a ticket on my help desk so I can keep track of it
        Cheers,
        Bob
          OK
          Don
            I see you are using this:
            hs.PluginFunction("BLRain8Net", "1", "RequestStatus", Nothing)
            So you have a BLRain8Net instance named "1"?
            Cheers,
            Bob
              No, the instance is named 'Main'.
              Unless I'm misunderstanding the docs, it's asking for the address. I'll try 'Main' and see if that helps.
              Don
                My bad - the doc is wrong
                Try this:
                hs.PluginFunction("BLRain8Net", "", "RequestStatus", New Object(){"1"})
                Cheers,
                Bob
                  That worked. Thanks.
                  I might have a bad controller, as nothing is coming back... SH#T!
                  Don
