Problem with Calendar Function on Rain8Net Pro2
  • Problem with Calendar Function on Rain8Net Pro2
    The new version of the Plug-in (1.0.11.0) is working fine with the Rain8Net Pro2. Thanks for the update.
    For some reason the Calendar function (report that shows how all sprinklers or scheduled) has stopped working and in fact causes a critical error in the plugin when invoked, and then disables access to the plugin for any other function. In fact it disables ALL plugin (Manage Plugin) access for an extended period of time (10-15 seconds). The plugin seems to get reset after another HS3 plugin event occurs, and all Rain8Net plugin functions start working again. However the calendar function, when invoked again, creates the same cycle of critical errors and all other plugin accesses.
    Below is a log ..
    Oct-22 5:45:12 AM ZONE OFF Zone: - Sprinkler Master - Zone 5 is now Off
    Oct-22 5:45:07 AM ZONE ON Zone: - Sprinkler Expansion - Zone 1 is now Watering
    Oct-22 5:44:54 AM Warning Plugin BLRain8Net is not responding but it is still running, not restarting yet.
    Oct-22 5:43:54 AM Warning Plugin BLRain8Net is not responding but it is still running, not restarting yet.
    Oct-22 5:42:54 AM Warning Plugin BLRain8Net is not responding but it is still running, not restarting yet.
    Oct-22 5:42:50 AM Error Getting plugin GenPage: Object reference not set to an instance of an object.
    Oct-22 5:38:27 AM Error Getting plugin GenPage: Object reference not set to an instance of an object.
    follow-up
    Should have mentioned in last Posting ... I did go through the cycle of removing the Plugin, rebooting HS3, reloading the plugin again. The calendar worked the first time, but then after that, it went into "critical error" mode again.
      Can you log a ticket on my web site and turn on debug logging in the plugin and capture the issue, then disable debug logging and attach the BLRain8Net-Detailed.log file zipped to the ticket
      Cheers,
      Bob
