EZFLora stopped working
  • EZFLora stopped working
    I'm not sure what happened but my EZFlora, which was working perfectly for quite a while now lost all it's devices. I saw that some others also had the same problems and fixed it by modifying the ini file and restarting Homeseer. I followed along and now I'm getting this message in the log file:
    3/21/2013 9:18:57 PM - Insteon - Error: An attempt was made to initialize an external Insteon device ID# 19.AA.F7. This device is already supported within the plug-in itself. The request was denied.
    I can't for the life of me figure this out. There's no reference to the ID numbers in any of the files. Any help would be appreciated.
    Greg
    Greg
    Greg,
    It appears as though your EZFlora device is being registered with the Insteon plugin instead of the EZFlora plugin. From the "Insteon Configuration" tab go into the "Manage Devices" section and verify that your EZFlora ID is not showing up in the list of registered devices. If it doesn't show up there, you may need to manually search the Insteon.ini file and make sure that it is not listed there and let me know the results.
    Adam
      Thanks Adam, that seems to have fixed things.
      -Greg
