EZFlora - not working
  • EZFlora - not working
    i am trying to run this plugin but no luck :/ anyone knows what is wrong here?
    here is my log. HS3 Pro Edition 3.0.0.280 (Windows) / plugin 2.0.0.1
    Thanks!
    May-30 01:41:42
    EZFlora Info Insteon Plugin Not Ready May-30 01:41:42 EZFlora Debug Entered RegisterDevices() subroutine. May-30 01:41:40 EZFlora Info Insteon Plugin Not Ready May-30 01:41:40 EZFlora Debug Entered RegisterDevices() subroutine. May-30 01:41:38 EZFlora Info Insteon Plugin Not Ready May-30 01:41:38 EZFlora Debug Entered RegisterDevices() subroutine.
    What version of the mnsandler Insteon Plugin do you have and is the plugin enabled?
    Adam
      Adam
      Adam, do you mean the HSInsteon plugin? It is 1.0.0.9 .... it is enabled, i am able to control lighting fine.It is teh free version that is included in HS3 PRO ... should I get this instead? http://store.homeseer.com/store/MNSa...HS3-P1679.aspx
      THanks!
        SOLVED
        enabling mnsandler Insteon Plugin worked, thanks!
          Glad you got it working. The mnSandler Insteon plugin is required for the EZFlora plugin to work. It will not work with the free HomeSeer Insteon plugin.
          Adam
            I tried Making a new thread for my issue but it seems the site kept asking me to login even after I am logged in...
            I am running EZ Flora v 2.0.0.1
            And I just got sod put down, and am trying to setup the manual timers, and trhe program timers..
            I set program 1 timers to 90 mins for 4 zones, and 0 for the rest, as I only have 4 zones..
            and now I cant get into ANY timers to check that they are set..
            If I edit the device, and select manual timers, or even program 1 timers.
            it says loading timer data, screen flashes twice saying loading timer data, then comes back with...
            Error getting timer data
            edit 1 program timers
            and its empty
            Reload or cancel
            PLEASE HELP ASAP < I just got SOD put down and I need to make sure my sprinklers are watering properly..
            here is the debugging log turned on then tried changing program 1 timer
            Jul-18 5:13:55 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = main_loglevel=1&id=main_save&main_save=Submit user = Taz userRights = 6
            Jul-18 5:13:53 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring =
            Jul-18 5:13:53 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = &id=editdevice_cancel&editdevice_cancel=Submit user = Taz userRights = 6
            Jul-18 5:13:48 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = editdevice
            Jul-18 5:13:48 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = &id=loading_cancel&loading_cancel=Submit user = Taz userRights = 6
            Jul-18 5:13:45 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = action=timeout user = Taz userRights = 6
            Jul-18 5:13:40 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = loading
            Jul-18 5:13:40 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = action=timeout user = Taz userRights = 6
            Jul-18 5:13:37 PM EZFlora Debug HSEvent GENERIC Case: Parms = ACK 44 02 01 3D D1 D9 33 5F 1C 2F 44 82
            Jul-18 5:13:37 PM EZFlora Debug Entered HSEvent GENERIC Case
            Jul-18 5:13:37 PM EZFlora Info EZFlora 3D.D1.D9 all programs off
            Jul-18 5:13:37 PM EZFlora Debug Entered ProcessProgramsOff() subroutine.
            Jul-18 5:13:37 PM EZFlora EZFlora 3D.D1.D9 valve 3 active
            Jul-18 5:13:37 PM EZFlora Debug Entered ProcessValveStatus() subroutine.
            Jul-18 5:13:37 PM EZFlora Debug HSEvent GENERIC Case: Parms = 01 3D D1 D9 33 5F 1C 2F 44 82
            Jul-18 5:13:36 PM EZFlora Info Configuration Status: Rain Sensor Enabled: False Rain Detected: False Broadcast Meter Messages: False Broadcast Valve Messages: False Daignostic Mode Enabled: False
            Jul-18 5:13:36 PM EZFlora Debug Entered ProcessConfigRegister() subroutine.
            Jul-18 5:13:36 PM EZFlora Debug HSEvent GENERIC Case: Parms = 01 3D D1 D9 33 5F 1C 2F F0 00
            Jul-18 5:13:36 PM EZFlora Debug Entered HSEvent GENERIC Case
            Jul-18 5:13:36 PM EZFlora Debug HSEvent GENERIC Case: Parms = ACK F0 00 01 3D D1 D9 33 5F 1C 2F F0 00
            Jul-18 5:13:36 PM EZFlora Info Polling DEVICE 1 with address of 3D.D1.D9
            Jul-18 5:13:36 PM EZFlora Debug Entered TimedPoll() subroutine.
            Jul-18 5:13:35 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = loading
            Jul-18 5:13:35 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = action=timeout user = Taz userRights = 6
            Jul-18 5:13:35 PM EZFlora Debug Entered HSEvent GENERIC Case
            Jul-18 5:13:30 PM EZFlora Debug HSEvent GENERIC Case: Parms = ACK 45 01 01 3D D1 D9 33 5F 1C 2B 45 01
            Jul-18 5:13:30 PM EZFlora Debug Entered HSEvent GENERIC Case
            Jul-18 5:13:30 PM EZFlora Debug HSEvent GENERIC Case: Parms = 01 3D D1 D9 33 5F 1C 2B 45 01
            Jul-18 5:13:30 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = loading
            Jul-18 5:13:30 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = &id=editdevice_program1&editdevice_program1=Submit user = Taz userRights = 6
            Jul-18 5:13:28 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = editdevice
            Jul-18 5:13:28 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = DEVICE1=checked&cb_DEVICE1=on&id=main_edit&main_edit=Submit user = Taz userRights = 6
            Jul-18 5:13:25 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring =
              Please see my response to your other post.
              Adam
