Hi,
I have an Oregon UVN800 UV sensor that integrates with HS via Blade's BLRF plugin. The sensor works and populates a device in HS (images attached).
The device is set as address code O8. The wind, temperature and humidity sensors, also via BLRF, work in mcsSprinklers using similar address codes (see images attached).
I have the mcsSprinklers weather setup to use HS device O8 for the UV. But mcsSprinklers always gets the UV from WeatherUnderground. I can not get it to use my UV sensor....ever.
Is there something I am doing wrong? Is it an issue with the way BLRF reports the device string?
I am having a similar issue with my PCR800 rain sensor. But this is faulty now (water ingress onto the circuit board). So I will have to address that when the replacement arrives. In the meantime I am getting rainfall data from WU.
Thanks, Marty.
mcsSprinklers Version 2.17.0.4
BLRF Version 2.0.89.0
HS3 Version 3.0.0.297 (Windows)
Thanks, Marty.
