InitEtherRain Conversion from string
  • InitEtherRain Conversion from string
    Michael, I upgraded to v2.19.1.0 today and received a strange error during installation. Is this error likely to impact my normal operations?
    Mar-25 11:53:17 AM mcsSprinklers InitEtherRain Conversion from string "" to type 'Short' is not valid.
    Incidentally, I use the Rain8net, not an EtherRain.
    Mar-25 11:53:19 AM Plug-In Finished initializing plug-in MCSSPRINKLERSP
    Mar-25 11:53:19 AM Starting Plug-In MCSSPRINKLERSP loaded in 6455 milliseconds
    Mar-25 11:53:19 AM Starting Plug-In Plugin MCSSPRINKLERSP started successfully in 6138 milliseconds
    Mar-25 11:53:14 AM mcsSprinklers Version 2.19.1.0 | V2.19.1.0/2.19.1.0 (Professional) Copyright 2004-2019 mcsSolutions Registered with Homeseer
    Mar-25 11:53:14 AM Warning Attempt by plugin to register a duplicate link of help. Plugin: Z-Wave Instance:
    Mar-25 11:53:12 AM Starting Plug-In Initializing plugin MCSSPRINKLERSP ...
    Mar-25 11:53:12 AM Info Plugin MCSSPRINKLERSP has connected. xxxxxxxxxxx
    Mar-25 11:52:39 AM Updater Install/Update of package mcsSprinklers Professional was successful.
    Mar-25 11:52:39 AM Updater Copying file: C:\homeseer_hs3pro\HSPI_MCSSPRINKLERSP.exe.config
    Mar-25 11:52:39 AM Updater Copying file: C:\homeseer_hs3pro\RESTART.exe
    Mar-25 11:52:39 AM Updater Copying file: C:\homeseer_hs3pro\MCSSPRINKLERS_2009.dll
    Mar-25 11:52:39 AM Updater Extraction Complete.
    Mar-25 11:52:37 AM Updater Extracting files from zip file: setup_hs.zip
    Mar-25 11:52:37 AM Updater Installing package mcsSprinklers Professional
    Mar-25 11:52:37 AM Updater Update hspi_mcssprinklersp.exe downloaded successfully
    Mar-25 11:52:36 AM Updater Downloading update: mcsSprinklers Professional
    Mar-25 11:52:36 AM Updater Starting download of updates
    Gary
    Current Date/Time: 3/25/2019 11:58:53 AM
    System Uptime: 0 Days 11 Hours 53 Minutes 38 Seconds
    IP Address: 192.168.1.83
    Number of Devices: 269
    Number of Events: 97
    Available Threads: 800
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    In Virtual Machine: No MFG: asustek computer inc.
    Enabled Plug-Ins
    2.0.57.0: BLBackup
    2.0.66.0: BLOnkyo
    1.0.4.0: BLShutdown
    2.19.1.0: MCSSPRINKLERSP
    30.0.0.37: RFXCOM
    3.0.6551.16959: UltraGCIR3
    3.0.0.40: X10
    3.0.1.252: Z-Wave
    Also, I just received an email from mcsSprinklers informing me that my API key was not found. When I go into the configuration, it shows (all dots) that there is a key there and it worked fine in the prior version. Let me know what I need to do please.
    Gary
    3/25/2019 11:54:16 AM | ControlSystemASP sprinkler
    3/25/2019 11:54:16 AM | mcsSprinklers | WeatherUnderground Forecast Download Error:type": "keynotfound"
    3/25/2019 11:56:01 AM | mcsSprinklers | WeatherUnderground Forecast Download Error:type": "keynotfound"
    3/25/2019 11:58:01 AM | mcsSprinklers | WeatherUnderground Forecast Download Error:type": "keynotfound"
    3/25/2019 12:00:01 PM | mcsSprinklers | WeatherUnderground Forecast Download Error:type": "keynotfound"
      Michael, when I went into weather setup, the Weather Source after the upgrade was shown as None (even though I was getting the WUG keynotfound error). When I changed to use WUG, I received the keynotfound error (below). I then reentered my WU API key and received the
      ‚Äč
      Gary
      Mar-25 12:14:21 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
      Mar-25 12:13:19 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
        The error in your first post was fixed in 2.19.1.1. It does not affect operation other than showing in the log. It is at http://mcsSprinklers.com/mcsSprinklers_21911.zip if you want to remove the log error.
        WeatherUnderground has eliminated their free API. I left the WUG code until this settles out as I think the direction IBM is going is to provide free keys for those who do data uploads. My recommendation now is to use one of the other services. OpenWeatherMap is what I use. APIXU is the last one I added.
          Ok, but how do I get rid of the log error message for WUG. It still occurs about every 2 minutes. I got the free OWM API key, entered it and selected the Use Open Weather Map option box but I still get the WUG error.
          Gary
          Mar-25 1:54:19 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
          Mar-25 1:54:18 PM mcsSprinklers Sprinklers now inhibited due to: Inhibit Today Area 1
          Mar-25 1:53:21 PM Plug-In Finished initializing plug-in MCSSPRINKLERSP
          Mar-25 1:53:21 PM Starting Plug-In MCSSPRINKLERSP loaded in 5802 milliseconds
          Mar-25 1:53:21 PM Starting Plug-In Plugin MCSSPRINKLERSP started successfully in 5407 milliseconds
          Mar-25 1:53:17 PM mcsSprinklers Version 2.19.1.1 | V2.19.1.1/2.19.1.1 (Professional) Copyright 2004-2019 mcsSolutions Registered with Homeseer
          Mar-25 1:53:17 PM Warning Attempt by plugin to register a duplicate link of help. Plugin: Z-Wave Instance:
          Mar-25 1:53:16 PM Starting Plug-In Initializing plugin MCSSPRINKLERSP ...
            Mar-25 2:16:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            Mar-25 2:14:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            Mar-25 2:12:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            Mar-25 2:10:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            Mar-25 2:08:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            Mar-25 2:06:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            Mar-25 2:04:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            Mar-25 2:02:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            Mar-25 2:00:03 PM email Email successfully sent to xxxx@gmail.com <-- THIS IS BEING SENT TO TELL ME ABOUT THE "keynotfound"
            Mar-25 2:00:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            Mar-25 1:58:01 PM mcsSprinklers WeatherUnderground Forecast Download Error:type": "keynotfound"
            I have disabled mcsSprinklers until you can get back to me with a fix.
            Gary
            Current Date/Time: 3/25/2019 2:20:37 PM
            System Uptime: 0 Days 0 Hours 35 Minutes 59 Seconds
            Event Threads: 0
            Email Send Queue: 0
            Enabled Plug-Ins
            2.0.57.0: BLBackup
            2.0.66.0: BLOnkyo
            1.0.4.0: BLShutdown
            2.19.1.0: MCSSPRINKLERSP <--- NOTE: I upgraded to Version 2.19.1.1 (see above post startup), yet this still says Version 2.19.1.0
            30.0.0.37: RFXCOM
            3.0.0.40: X10
            3.0.1.252: Z-Wave
              It is telling you about the forecast source. I suspect you still have WU setup for the forecast source which is setup just below what you are showing in the screenshot.
              The zip link I gave was for a patch file. It did not change the parent .exe that HS sees. If you want the full updater file then it is at http://mcsSprinklers.com/mcsSprinkle...19_1_1_HS3.zip. Extract the HSPI_...exe file.
                Ok, thanks Michael. I switched to AccuWeather and I don't have (any) error messages. Is that a valid alternate forecast resource? The API key appears to be hard coded, because I do not have one.
                On a related subject, I signed up for the APIXU free service but when I select the APIXU option, how do I entered its API key?
                Probably just me, but it may be more clear if the error message(s) made mention of the "Alternate Source" as being the one that is invalid.
                Thanks much for your quick support.
                Gary
                  Do these Weather downloads look right to you? Neither OWN nor APIXU show any forcast info. Am I looking at this wrong?
                  Gary
                  IMAGE BELOW:
                    I remove the text box for Accuweather key. It is 2.19.1.2 on mcsSprinklers.com using same convention as prior version.
                    All other license/api keys are in the section for weather source, including APIXU.
                    Forecast is only downloaded for the selected forecast source. You have Accuweather selected for the forecast. APIXU/OWM was selected for current weather conditions.
                      Thanks Michael, that helps. To be clear, you use OWM for both?
                      Gary
                        My understanding is that you can use separate sources.
                          Thanks langenet, I believe you are correct. I was interested in what Michael does. Currently I am using OWM for both the Weather source AND the Forecast source, but I don't know if there is any advantage to using different services. In my case, most of my (current) weather data for mcsSprinklers comes from my weather station, so mostly here I am interested in the most reliable "forecast" service/setting(s).
                          Gary
                            I was using WeatherUndrerground last year for both. Now I am using OWM for both. It has worked well for me. It seems to be the most friendly provider. APIXU does have usage limits.
                              Thanks Michael. Hopefully WUG will get back in the game sometime soon. My Weather Station reports to them so it would be good to have them as a source again.
                              Gary
