Hi Michael, the morning R3 ran as expected at 07:00 for 5 minutes. It is scheduled to run again at 19:00 today. At 8:04 I ran R4 manually from the Zone Status page for 60 minutes to see how it behaved and it shut off at 9:04 as expected. From the time I manually started R4 at 8:04, I noticed that R3 began to exhibit a one-minute walking delay and it continues to do so but never starts. I had removed the inhibits yesterday per my previous message. That zone (R3) is scheduled in the program to run again at 19:00 so we'll see what happens then.
Question: Are the maximum valve times still 60 minutes on the GoControl or have you found a way around that? I ask this because I note in the DEBUG log that the GoControl command is for a 30 minute duration even though the timer in mcsSprinklers is set for 60 minutes. HS3 also reports it as a 30 min duration. Something going on under the hood maybe as I would have expected HS3 to shut the valve off after 30 but don't see the CAPI shut off command for a full 60 minutes. All good... just curious.
In Debug: GoControl Parms(2)/Status=7684, Parms(4)/Ref=937
HS3 Log:
HS3 Log:
May-20 8:04:46 AM | Device Control | Device: Sprinklers Backyard Irrigation Valve to Valve 4 On for 30 min (7684) by/from: CAPI Control Handler |
