Why both Standard and Pro versions installed?
    In HS3 updater only Pro version of the plug in is listed for purchase, but when I download from updater, both Standard and Pro versions are installed. Do I just deleted the Standard? Understood there used to be B/S/P versions in HS2 but it looks like only Pro version is offered now. (I already have Pro for HS2 but want to update to HS3 instead of running stand alone).
    For Homeseer 3 Standard and Pro used to be the same except for the license which would designate Standard or Pro.
    So when you download HS3 and license it; it will be Standard or Pro. It is only one program.
    Auto mator
      On HS3 plug in management tab, should I register under Pro and delete Standard?
      In HS2 Pro version has more features than Standard (for example calculates evaporations etc). Is HS3 version basically equivalent to the Pro version in HS2?
        As of about a year ago I removed the Standard and Basic versions from the HS store. For those that had previously bought the Standard I include it in the updater with the Pro version so they can get the updates that are being made. The version for which you have a license should be the one enabled. The other HSPI_xxx.exe can be deleted.
