Stand alone vs plug in?
  • Stand alone vs plug in?
    Happy Thanksgiving!
    I remember reading in a threat that running mcsSprinkler as stand alone, with a weaker coupling to HS through xAP, makes the system more stable than running it as a HS plug in.
    I currently run mcsSprinkler as a HS plug in. Besides using HS rain sensor, rain gauge etc, the only thing I need HS for the sprinkler is once a year I run an event to blow out sprinkler before winter (turn on one zone for a 1 min, wait for 5 min to let compressor regard, then more on to next zone etc). Would it be easy to do the same thing in HS if I run stand alone version instead of a plug in?
    I run mcsSprinklers as a stand alone on a separate computer and use xAP to couple to HS. It works well and has been quite reliable. I like the combination because it decouples the sprinkler control from HS, allowing it to run autonomously.
    What I don't like is that setting up mcsXap involves a learning curve. It's not difficult, but it can be a pain because it's not entirely intuitive for me. Unfortunately, whenever you move either HS or mcsSprinkers to a different box, you have to reconstruct the xAP link, which for me, involves relearning the details of setting up the interface. Not difficult, but it requires time and attention.
    HS3 Pro Edition 3.0.0.548
      As Uncle Michael indicated mcsSprinklers does support an automation interface. It has three forms. The original is xAP protocol and scripting. Last year MQTT was also added as a protocol. Whatever you do with the pluign you should also be able to do with the standalone.
