Negative scheduled time after manual control
    Hi Micheal, while I was testing USB/serial convertor with Rain8Net, I manually turned on then quickly turned off one zone multiple times. After that I noticed the next schedule for that zone showed a larger negative minutes on Run List tab. I am guessing mcsSprinklers is trying to deduct the manual irrigation time from the normal scheduled length for that zone, but instead of using the time that zone is actually turned on, it is deducting number of manual cycle * full length of manual cycle (even though the manual cycle was stopped quickly). So for example, if that zone is turned on then turned off after 1 min 10 times, and normal manual cycle is 10 min, the program will deduct 100 min from the auto cycle instead of 10 min.
    I was not able to replicate. How did you turn on/off valve? Do you have the debug from your test session?
