Assistance with valve closing
    Hi,
    This was moved here from another thread. I turned on a sprinkler zone manually from my phone using the "general status" while I adjusted the head. The sprinkler head came on briefly, then shut off. I had to turn it off from the general status and then on again, and it shut itself off. On the third time, it stayed on. This is using the GoControl controller- in which an off command turns off ALL zones and only one can be on at a time.
    I think I see the issue, the GoControl only allows one Zone to be on at one At 4:07 the Back lawn goes off, but the front lawn is on. That shuts everything off.
    HS LOG
    Jun-23 4:08:16 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Valve 4 On for 30 min (7684) by/from: CAPI Control Handler
    Jun-23 4:08:16 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Off (0) by/from: CAPI Control Handler
    Jun-23 4:08:01 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Off (0) by/from: CAPI Control Handler
    Jun-23 4:07:42 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Off (0) by/from: CAPI Control Handler
    Jun-23 4:07:31 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Valve 4 On for 30 min (7684) by/from: CAPI Control Handler
    Jun-23 4:07:31 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Off (0) by/from: CAPI Control Handler
    Jun-23 4:07:27 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Off (0) by/from: CAPI Control Handler
    Jun-23 4:07:15 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Off (0) by/from: CAPI Control Handler
    Jun-23 4:07:00 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Off (0) by/from: CAPI Control Handler
    Jun-23 4:06:49 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Valve 4 On for 30 min (7684) by/from: CAPI Control Handler
    Jun-23 4:06:36 PM Device Control Device: Basement Water Closet Sprinker Controller Valve to Off (0) by/from: CAPI Control Handler
    RUN LOG
    6/23/2020 4:06:36 PM A1:R3 Rain8 Front Lawn Inner OFF
    6/23/2020 4:06:49 PM A1:R4 Rain8 Front Lawn Outer ON
    6/23/2020 4:07:00 PM A2:R10 Rain8 Porch Back OFF
    6/23/2020 4:07:15 PM A1:R4 Rain8 Front Lawn Outer OFF
    6/23/2020 4:07:31 PM A1:R4 Rain8 Front Lawn Outer ON
    6/23/2020 4:07:42 PM A1:R4 Rain8 Front Lawn Outer Forced OFF
    6/23/2020 4:07:42 PM A1:R4 Rain8 Front Lawn Outer External ON
    6/23/2020 4:08:01 PM A1:R4 Rain8 Front Lawn Outer OFF
    6/23/2020 4:08:16 PM A1:R4 Rain8 Front Lawn Outer ON
    6/23/2020 4:28:17 PM A1:R4 Rain8 Front Lawn Outer OFF
    Sprinkler LOG
    6/23/2020 4:07:00 PM 637285252209384704 | mcsSprinklers Debug | BackupWeather AWS Time=30, InternalAWS(0)=1/1/2000, InternalAWS(3)=1/1/2000, LastAWSDate=1/1/2000, rtdLastNWSDate=1/1/2000, rtdLastWeatherXMLBackupDate=6/20/2020 1:02:00 AM
    6/23/2020 4:07:00 PM 637285252209384704 | mcsSprinklers Debug | GetWUForecast iContent=0
    6/23/2020 4:07:00 PM 637285252209384704 | mcsSprinklers Debug | InterfaceMonitoring=False
    6/23/2020 4:07:15 PM 637285252357513230 | mcsSprinklers Debug | ManualEnable=False,False,False,False,False,False,False,False ,False,False,False,False, Override=True, ASPStop=False, bTransitionToManualMode=False, rtbPreviousModeIsAuto=False
    6/23/2020 4:07:15 PM 637285252357683246 | mcsSprinklers Debug | ReadAll C:\Program Files (x86)\HomeSeer HS3\Data\mcsSprinklers\mcsSprinklers_State.ini ,Length=67, FileLength=67
    6/23/2020 4:07:15 PM 637285252357683246 | mcsSprinklers Debug | TSONet Close C:\Program Files (x86)\HomeSeer HS3\Data\mcsSprinklers\mcsSprinklers_State.ini ,FileLength=67
    6/23/2020 4:07:15 PM 637285252357683246 | mcsSprinklers Debug | Links=<center><p>| <a href="/interview" target="_top">Setup Interview</a>| | <a href="/rain8" target="_top">Interface Setup</a>| | <a href="/wiring" target="_top">Wiring Setup</a>| | <a href="/layout" target="_top">Layout Setup</a>| | <a href="/zone" target="_top">Zones Setup</a>| | <a href="/area" target="_top">Areas Setup</a>||<br>| <a href="/program" target="_top">Programs Setup</a>| | <a href="/site" target="_top">Site Setup</a>| | <a href="/sensor" target="_top">Weather Setup</a>| | <a href="/remote" target="_top">Remote Setup</a>| | <a href="/other" target="_top">Other Setup</a>| | <a href="/pictureentry" target="_top">Picture Entry</a>| <br>| <a href="/help" target="_top">Help</a>| | <a href="/sprinkler" target="_top">Zones Status</a>| | <a href="/generalstatus" target="_top">General Status</a>| | <a href="/runlist" target="_top">Run List</a>| | <a href="/log" target="_top">Run Log</a>| | <a href="/touch" target="_top">Touch Zone</a>| | <a href="/toucharea" target="_top">Touch Area</a>| | <a href="/iowindow" target="_top">Serial IO</a>| | <a href="/reminders" target="_top">Reminders</a>| </p></center>
    6/23/2020 4:07:15 PM 637285252358103254 | mcsSprinklers Debug | SetSyringing Trigger= False,State=, Temp=88 .vs 89/-9999, Time=6/23/2020
    6/23/2020 4:07:15 PM 637285252358403255 | mcsSprinklers Debug | Transition out of Manual Zone 3, Area=0, OnStatus=True, ExitManual=True, bTurnoff=False, bTurnOffArea(iArea)=False, AreaInhibitText=, SiteInhibitText=, bKeepZoneOn=False, bOverride=True
    6/23/2020 4:07:15 PM 637285252358423254 | mcsSprinklers Debug | FormatSprinklerZoneOnly R4=OFF|3
    6/23/2020 4:07:15 PM 637285252358423254 | mcsSprinklers Debug | SetDeviceStatus(R4) iStatus=3, iHSStatus=3
    6/23/2020 4:07:15 PM 637285252358433252 | mcsSprinklers Debug | FormatSprinkler Change=True, StatusChange=True, DC=R4
    6/23/2020 4:07:15 PM 637285252358433252 | mcsSprinklers Debug | ExecX10 R4=off for 0
    6/23/2020 4:07:15 PM 637285252358433252 | mcsSprinklers Debug | CommonExecX10, Rain8NetUPB HouseCode=R, Device=R4, State=OFF, rtoX10CollectionCount=0, iType=9
    6/23/2020 4:07:15 PM 637285252358433252 | mcsSprinklers Debug | LogAction INSERT INTO log (SampleDate,Device,Status) VALUES('2020-06-23 16:07:15','R4','OFF')
    6/23/2020 4:07:15 PM 637285252358553262 | mcsSprinklers Debug | GoControl Command R4 to OFF for 0
    6/23/2020 4:07:20 PM 637285252403175848 | mcsSprinklers Debug | CheckManual Was rtdZoneDeviceLastChange(3)=6/23/2020 3:45:15 PM, NowIs=6/23/2020 4:07:20 PM
    6/23/2020 4:07:20 PM 637285252403175848 | mcsSprinklers Debug | SetDeviceStatus(S95) iStatus=2, iHSStatus=2
    6/23/2020 4:07:20 PM 637285252403215849 | mcsSprinklers Debug | Links=<center><p>| <a href="/interview" target="_top">Setup Interview</a>| | <a href="/rain8" target="_top">Interface Setup</a>| | <a href="/wiring" target="_top">Wiring Setup</a>| | <a href="/layout" target="_top">Layout Setup</a>| | <a href="/zone" target="_top">Zones Setup</a>| | <a href="/area" target="_top">Areas Setup</a>||<br>| <a href="/program" target="_top">Programs Setup</a>| | <a href="/site" target="_top">Site Setup</a>| | <a href="/sensor" target="_top">Weather Setup</a>| | <a href="/remote" target="_top">Remote Setup</a>| | <a href="/other" target="_top">Other Setup</a>| | <a href="/pictureentry" target="_top">Picture Entry</a>| <br>| <a href="/help" target="_top">Help</a>| | <a href="/sprinkler" target="_top">Zones Status</a>| | <a href="/generalstatus" target="_top">General Status</a>| | <a href="/runlist" target="_top">Run List</a>| | <a href="/log" target="_top">Run Log</a>| | <a href="/touch" target="_top">Touch Zone</a>| | <a href="/toucharea" target="_top">Touch Area</a>| | <a href="/iowindow" target="_top">Serial IO</a>| | <a href="/reminders" target="_top">Reminders</a>| </p></center>
    6/23/2020 4:07:27 PM 637285252472549823 | mcsSprinklers Debug | CommonExecX10, Rain8NetUPB HouseCode=R, Device=R4, State=OFF, rtoX10CollectionCount=0, iType=9
    6/23/2020 4:07:27 PM 637285252472549823 | mcsSprinklers Debug | GoControl Command R4 to OFF for 0
    6/23/2020 4:07:31 PM 637285252510052120 | mcsSprinklers Debug | GoControl Command Retry R4 to OFF for 0
    6/23/2020 4:07:31 PM 637285252510071989 | mcsSprinklers Debug | AddAction R4=off, Dur=0, Path=2
    6/23/2020 4:07:31 PM 637285252510071989 | mcsSprinklers Debug | LogValveAction R4=off, Path=2
    6/23/2020 4:07:31 PM 637285252510071989 | mcsSprinklers Debug | Log Discrete INSERT INTO dR4 (SampleDate,Discrete) VALUES('2020-06-23 16:07:31',0)
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | bKeepZoneOn=False, bTurnOff=False, bTurnOffArea=False,False,False,False,False,False,False,False ,dTimeLastIteration=6/23/2020 4:07:00 PM, Transition=False,PrevAutoMode=False, AverageWind=0,SiteInhibit=,AreaInhibit=||||||||
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=3, Zone=0/R1, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=10, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=0, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=180, rtiZoneCumMinutes=673, rtnZoneCalculatedMoistureLevel(iZone)=0.5654022, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=True, rtdZoneDeviceLastChange(iZone)=6/23/2020 9:55:03 AM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=3, Zone=1/R2, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=10, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=0, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=180, rtiZoneCumMinutes=655, rtnZoneCalculatedMoistureLevel(iZone)=0.5654022, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=True, rtdZoneDeviceLastChange(iZone)=6/23/2020 11:20:04 AM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=23, Zone=2/R3, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=70, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=0, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1380, rtiZoneCumMinutes=1561, rtnZoneCalculatedMoistureLevel(iZone)=0.56609, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=False, rtdZoneDeviceLastChange(iZone)=6/23/2020 3:44:36 PM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=23, Zone=3/R4, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=70, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=0, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1380, rtiZoneCumMinutes=1542, rtnZoneCalculatedMoistureLevel(iZone)=0.9916795, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=False, rtdZoneDeviceLastChange(iZone)=6/23/2020 4:07:20 PM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=23, Zone=4/R5, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=70, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=0, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1380, rtiZoneCumMinutes=1472, rtnZoneCalculatedMoistureLevel(iZone)=0.5541059, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=True, rtdZoneDeviceLastChange(iZone)=6/20/2020 2:04:00 PM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=17, Zone=5/R6, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=50, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=0, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1020, rtiZoneCumMinutes=903, rtnZoneCalculatedMoistureLevel(iZone)=0.56448, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=True, rtdZoneDeviceLastChange(iZone)=6/23/2020 11:49:00 AM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=17, Zone=6/R7, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=50, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=0, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1020, rtiZoneCumMinutes=1750, rtnZoneCalculatedMoistureLevel(iZone)=0.563416, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=False, rtdZoneDeviceLastChange(iZone)=6/23/2020 12:09:00 PM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=25, Zone=7/R10, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=75, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=1, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1500, rtiZoneCumMinutes=1570, rtnZoneCalculatedMoistureLevel(iZone)=0.9361861, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=True, rtdZoneDeviceLastChange(iZone)=6/23/2020 4:07:00 PM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=20, Zone=8/R11, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=60, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=1, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1200, rtiZoneCumMinutes=1496, rtnZoneCalculatedMoistureLevel(iZone)=0.8161861, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=False, rtdZoneDeviceLastChange(iZone)=6/23/2020 3:28:30 PM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=22, Zone=9/R12, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=65, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=1, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1320, rtiZoneCumMinutes=1070, rtnZoneCalculatedMoistureLevel(iZone)=0.6654178, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=False, rtdZoneDeviceLastChange(iZone)=6/23/2020 3:41:44 PM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=17, Zone=10/R8, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=50, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=1, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1020, rtiZoneCumMinutes=1443, rtnZoneCalculatedMoistureLevel(iZone)=0.6738739, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=False, rtdZoneDeviceLastChange(iZone)=6/23/2020 1:49:00 PM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | iZoneDurationHour=25, Zone=11/R9, iZoneTimeSlot=0, rtiZoneDurationMonth(iZoneTimeSlot, iZone)=75, nAutoDuration=1, rtiAreaRoundRobinCount(iArea)=3, rtiZoneRoundRobinCount(iZone)=3, Area=1, rtnAreaNextStartDuration(iArea)=1, rtiZoneDurationSeconds=1500, rtiZoneCumMinutes=1554, rtnZoneCalculatedMoistureLevel(iZone)=0.6895193, rtnZoneRunTime=0, DeviceStatus=3, rtbZoneWateredToday(iZone)=False, rtdZoneDeviceLastChange(iZone)=6/23/2020 2:44:54 PM, bAreaZonePriorTurnOff(iArea)=False
    6/23/2020 4:07:31 PM 637285252510192147 | mcsSprinklers Debug | WaterUsedNotComputedList Count=0,iWaterNow(iArea)=0, rtiAreaWaterMeterReading(iArea)=0, hs.isOn(S45)=True, rtiZoneWaterUseHour(mZone)=0
    6/23/2020 4:07:31 PM 637285252510201962 | mcsSprinklers Debug | EvaluateNow bDoTurnOn=True, bDoTurnOnForMist=True, bTurnOff=False, rtbCarryover=False, bOverride=True, bDoTurnOnByArea=,True,True,True,True,True,True,True,True, RR Delay=,0,0,0,0,0,0,0,0, IZ Delay=,0,7,0,0,0,0,0,0
    6/23/2020 4:07:31 PM 637285252510201962 | mcsSprinklers Debug | rtbNotificationOfAreaStarting=False, rtiNotifyMinutes=0, rtbAreaCycleActive(0)=True,rtnAreaNextStartDuration(0)=1
    6/23/2020 4:07:31 PM 637285252510201962 | mcsSprinklers Debug | ValveOnLogic, rtbZoneTurnOn(0)=False, iValveOnCount(0)=0, iValveOnCountTotal=0, iFlowTotal=0, rtbZoneCarryover(0)=False, rtiAreaMaxZonesOn=1, rtiAreaMaxFlow=40, bCycleActiveSequential=False, rtnAreaNextStartDuration(0)=1, rtiZoneDurationMonth(0,0)=10, iValvesPowered=0
    6/23/2020 4:07:31 PM 637285252510201962 | mcsSprinklers Debug | ValveOnLogic, rtbZoneTurnOn(1)=False, iValveOnCount(0)=0, iValveOnCountTotal=0, iFlowTotal=0, rtbZoneCarryover(1)=False, rtiAreaMaxZonesOn=1, rtiAreaMaxFlow=40, bCycleActiveSequential=False, rtnAreaNextStartDuration(0)=1, rtiZoneDurationMonth(0,1)=10, iValvesPowered=0
    6/23/2020 4:07:31 PM 637285252510201962 | mcsSprinklers Debug | ValveOnLogic, rtbZoneTurnOn(2)=False, iValveOnCount(0)=0, iValveOnCountTotal=0, iFlowTotal=0, rtbZoneCarryover(2)=False, rtiAreaMaxZonesOn=1, rtiAreaMaxFlow=40, bCycleActiveSequential=False, rtnAreaNextStartDuration(0)=1, rtiZoneDurationMonth(0,2)=70, iValvesPowered=0
    6/23/2020 4:07:31 PM 637285252510201962 | mcsSprinklers Debug | ValveOnLogic, rtbZoneTurnOn(3)=True, iValveOnCount(0)=0, iValveOnCountTotal=0, iFlowTotal=0, rtbZoneCarryover(3)=False, rtiAreaMaxZonesOn=1, rtiAreaMaxFlow=40, bCycleActiveSequential=False, rtnAreaNextStartDuration(0)=1, rtiZoneDurationMonth(0,3)=70, iValvesPowered=0
    6/23/2020 4:07:31 PM 637285252510201962 | mcsSprinklers Debug | Sprinkler Valve R4 turned on with moisture at Calc=0.9916795-Meas=0.44/1 and ZonesPending=0.0.0.1.0.0.0.0.0.0.0.0
    6/23/2020 4:07:31 PM 637285252510201962 | mcsSprinklers Debug | 12500
    6/23/2020 4:07:31 PM 637285252510201962 | mcsSprinklers Debug | 12630
    6/23/2020 4:07:31 PM 637285252510311999 | mcsSprinklers Debug | Remaining Minutes R4,sOnOff=ON
    6/23/2020 4:07:31 PM 637285252510311999 | mcsSprinklers Debug | Remaining Minutes2 R4,hs.isOn(sDC)=False
    6/23/2020 4:07:31 PM 637285252510311999 | mcsSprinklers Debug | Remaining Minutes4 iRemainingMinutes2=20
    6/23/2020 4:07:31 PM 637285252510321997 | mcsSprinklers Debug | FormatSprinklerZoneOnly R4=ON|2
    6/23/2020 4:07:31 PM 637285252510321997 | mcsSprinklers Debug | SetDeviceStatus(R4) iStatus=2, iHSStatus=2
    6/23/2020 4:07:31 PM 637285252510361976 | mcsSprinklers Debug | FormatSprinkler Change=True, StatusChange=True, DC=R4
    6/23/2020 4:07:31 PM 637285252510361976 | mcsSprinklers Debug | ExecX10 R4=on for 21
    6/23/2020 4:07:31 PM 637285252510361976 | mcsSprinklers Debug | CommonExecX10, Rain8NetUPB HouseCode=R, Device=R4, State=ON, rtoX10CollectionCount=0, iType=9
    6/23/2020 4:07:31 PM 637285252510361976 | mcsSprinklers Debug | LogAction INSERT INTO log (SampleDate,Device,Status) VALUES('2020-06-23 16:07:31','R4','ON')
    6/23/2020 4:07:31 PM 637285252510501992 | mcsSprinklers Debug | GoControl Command R4 to ON for 21
    6/23/2020 4:07:42 PM 637285252624098500 | mcsSprinklers Debug | GoControl Command Retry R4 to OFF for 0
    6/23/2020 4:07:42 PM 637285252624118518 | mcsSprinklers Debug | Log Discrete INSERT INTO dR4 (SampleDate,Discrete) VALUES('2020-06-23 16:07:42',0)
    6/23/2020 4:07:42 PM 637285252624268522 | mcsSprinklers Debug | LogAction INSERT INTO log (SampleDate,Device,Status) VALUES('2020-06-23 16:07:42','R4','Forced OFF')
    6/23/2020 4:07:42 PM 637285252624388532 | mcsSprinklers Debug | Links=<center><p>| <a href="/interview" target="_top">Setup Interview</a>| | <a href="/rain8" target="_top">Interface Setup</a>| | <a href="/wiring" target="_top">Wiring Setup</a>| | <a href="/layout" target="_top">Layout Setup</a>| | <a href="/zone" target="_top">Zones Setup</a>| | <a href="/area" target="_top">Areas Setup</a>||<br>| <a href="/program" target="_top">Programs Setup</a>| | <a href="/site" target="_top">Site Setup</a>| | <a href="/sensor" target="_top">Weather Setup</a>| | <a href="/remote" target="_top">Remote Setup</a>| | <a href="/other" target="_top">Other Setup</a>| | <a href="/pictureentry" target="_top">Picture Entry</a>| <br>| <a href="/help" target="_top">Help</a>| | <a href="/sprinkler" target="_top">Zones Status</a>| | <a href="/generalstatus" target="_top">General Status</a>| | <a href="/runlist" target="_top">Run List</a>| | <a href="/log" target="_top">Run Log</a>| | <a href="/touch" target="_top">Touch Zone</a>| | <a href="/toucharea" target="_top">Touch Area</a>| | <a href="/iowindow" target="_top">Serial IO</a>| | <a href="/reminders" target="_top">Reminders</a>| </p></center>
    6/23/2020 4:07:42 PM 637285252625488579 | mcsSprinklers Debug | CheckManual Was rtdZoneDeviceLastChange(3)=6/23/2020 3:45:42 PM, NowIs=6/23/2020 4:07:42 PM
    6/23/2020 4:07:42 PM 637285252625488579 | mcsSprinklers Debug | SetDeviceStatus(S95) iStatus=2, iHSStatus=2
    6/23/2020 4:07:42 PM 637285252625578601 | mcsSprinklers Debug | Links=<center><p>| <a href="/interview" target="_top">Setup Interview</a>| | <a href="/rain8" target="_top">Interface Setup</a>| | <a href="/wiring" target="_top">Wiring Setup</a>| | <a href="/layout" target="_top">Layout Setup</a>| | <a href="/zone" target="_top">Zones Setup</a>| | <a href="/area" target="_top">Areas Setup</a>||<br>| <a href="/program" target="_top">Programs Setup</a>| | <a href="/site" target="_top">Site Setup</a>| | <a href="/sensor" target="_top">Weather Setup</a>| | <a href="/remote" target="_top">Remote Setup</a>| | <a href="/other" target="_top">Other Setup</a>| | <a href="/pictureentry" target="_top">Picture Entry</a>| <br>| <a href="/help" target="_top">Help</a>| | <a href="/sprinkler" target="_top">Zones Status</a>| | <a href="/generalstatus" target="_top">General Status</a>| | <a href="/runlist" target="_top">Run List</a>| | <a href="/log" target="_top">Run Log</a>| | <a href="/touch" target="_top">Touch Zone</a>| | <a href="/toucharea" target="_top">Touch Area</a>| | <a href="/iowindow" target="_top">Serial IO</a>| | <a href="/reminders" target="_top">Reminders</a>| </p></center>
    6/23/2020 4:07:42 PM 637285252628098739 | mcsSprinklers Debug | GoControl Parms(2)/Status=7684, Parms(4)/Ref=963, AcknowledgeExpected=2, ControlDevice=R4
    6/23/2020 4:07:42 PM 637285252628108746 | mcsSprinklers Debug | Commanding R4 to 2, is an Ailias=False,LastChange=6/23/2020 4:07:31 PM, Status=2
    6/23/2020 4:07:42 PM 637285252628108746 | mcsSprinklers Debug | Rain8 X10-2 status check Current=2, new=2
    6/23/2020 4:07:42 PM 637285252628108746 | mcsSprinklers Debug | Zone Manual On=False, zones ubound=11, alias zone=3, StatusRespone=False, iX10CommandedZone=3, iX10CommandedStatus=3, iStatus=2, iZone=3
    6/23/2020 4:07:42 PM 637285252628108746 | mcsSprinklers Debug | LogAction INSERT INTO log (SampleDate,Device,Status) VALUES('2020-06-23 16:07:42','R4','External ON')
    6/23/2020 4:07:42 PM 637285252628218727 | mcsSprinklers Debug | CheckManual Was rtdZoneDeviceLastChange(3)=6/23/2020 4:07:42 PM, NowIs=6/23/2020 4:07:42 PM
    6/23/2020 4:07:42 PM 637285252628218727 | mcsSprinklers Debug | SetDeviceStatus(S95) iStatus=2, iHSStatus=2
    6/23/2020 4:07:42 PM 637285252628258762 | mcsSprinklers Debug | Scheduling Manual Control from HSEvent
    6/23/2020 4:07:42 PM 637285252628618788 | mcsSprinklers Debug | 12640
    6/23/2020 4:07:42 PM 637285252628618788 | mcsSprinklers Debug | AddAction R4=on, Dur=0, Path=5
    6/23/2020 4:07:42 PM 637285252628618788 | mcsSprinklers Debug | LogValveAction R4=on, Path=2
    6/23/2020 4:07:42 PM 637285252628618788 | mcsSprinklers Debug | Log Discrete INSERT INTO dR4 (SampleDate,Discrete) VALUES('2020-06-23 16:07:42',1)
    6/23/2020 4:07:42 PM 637285252628738767 | mcsSprinklers Debug | OnCommand 12930 Was rtdZoneDeviceLastChange(3)=6/23/2020 4:07:42 PM, NowIs=6/23/2020 4:07:15 PM
    6/23/2020 4:07:42 PM 637285252628738767 | mcsSprinklers Debug | ValveOnLogic, rtbZoneTurnOn(7)=False, iValveOnCount(1)=0, iValveOnCountTotal=1, iFlowTotal=0, rtbZoneCarryover(7)=False, rtiAreaMaxZonesOn=1, rtiAreaMaxFlow=40, bCycleActiveSequential=False, rtnAreaNextStartDuration(1)=1, rtiZoneDurationMonth(0,7)=75, iValvesPowered=1
    6/23/2020 4:07:42 PM 637285252628738767 | mcsSprinklers Debug | ValveOnLogic, rtbZoneTurnOn(8)=False, iValveOnCount(1)=0, iValveOnCountTotal=1, iFlowTotal=0, rtbZoneCarryover(8)=False, rtiAreaMaxZonesOn=1, rtiAreaMaxFlow=40, bCycleActiveSequential=False, rtnAreaNextStartDuration(1)=1, rtiZoneDurationMonth(0,8)=60, iValvesPowered=1
    6/23/2020 4:07:42 PM 637285252628738767 | mcsSprinklers Debug | ValveOnLogic, rtbZoneTurnOn(9)=False, iValveOnCount(1)=0, iValveOnCountTotal=1, iFlowTotal=0, rtbZoneCarryover(9)=False, rtiAreaMaxZonesOn=1, rtiAreaMaxFlow=40, bCycleActiveSequential=False, rtnAreaNextStartDuration(1)=1, rtiZoneDurationMonth(0,9)=65, iValvesPowered=1
    6/23/2020 4:07:42 PM 637285252628738767 | mcsSprinklers Debug | ValveOnLogic, rtbZoneTurnOn(10)=False, iValveOnCount(1)=0, iValveOnCountTotal=1, iFlowTotal=0, rtbZoneCarryover(10)=False, rtiAreaMaxZonesOn=1, rtiAreaMaxFlow=40, bCycleActiveSequential=False, rtnAreaNextStartDuration(1)=1, rtiZoneDurationMonth(0,10)=50, iValvesPowered=1
    6/23/2020 4:07:42 PM 637285252628738767 | mcsSprinklers Debug | ValveOnLogic, rtbZoneTurnOn(11)=False, iValveOnCount(1)=0, iValveOnCountTotal=1, iFlowTotal=0, rtbZoneCarryover(11)=False, rtiAreaMaxZonesOn=1, rtiAreaMaxFlow=40, bCycleActiveSequential=False, rtnAreaNextStartDuration(1)=1, rtiZoneDurationMonth(0,11)=75, iValvesPowered=1
    6/23/2020 4:07:42 PM 637285252628758788 | mcsSprinklers Debug | RealTime dLastPredictionTime=6/23/2020 4:06:00 PM, rtiTouchPredictionSeconds=66
    6/23/2020 4:07:42 PM 637285252628898785 | mcsSprinklers Debug | AreaOn(0)=True
    6/23/2020 4:07:42 PM 637285252628908776 | mcsSprinklers Debug | Water Use Area 0=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252628928769 | mcsSprinklers Debug | AreaOn(1)=False
    6/23/2020 4:07:42 PM 637285252628928769 | mcsSprinklers Debug | Water Use Area 1=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252628948771 | mcsSprinklers Debug | AreaOn(2)=False
    6/23/2020 4:07:42 PM 637285252628948771 | mcsSprinklers Debug | Water Use Area 2=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252628978771 | mcsSprinklers Debug | AreaOn(3)=False
    6/23/2020 4:07:42 PM 637285252628978771 | mcsSprinklers Debug | Water Use Area 3=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629008778 | mcsSprinklers Debug | AreaOn(4)=False
    6/23/2020 4:07:42 PM 637285252629008778 | mcsSprinklers Debug | Water Use Area 4=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629058780 | mcsSprinklers Debug | AreaOn(5)=False
    6/23/2020 4:07:42 PM 637285252629058780 | mcsSprinklers Debug | Water Use Area 5=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629078795 | mcsSprinklers Debug | AreaOn(6)=False
    6/23/2020 4:07:42 PM 637285252629078795 | mcsSprinklers Debug | Water Use Area 6=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629108782 | mcsSprinklers Debug | AreaOn(7)=False
    6/23/2020 4:07:42 PM 637285252629108782 | mcsSprinklers Debug | Water Use Area 7=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629128784 | mcsSprinklers Debug | Water Use Area 8=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629138776 | mcsSprinklers Debug | Cycle Active(0)=True, Anything On=True
    6/23/2020 4:07:42 PM 637285252629138776 | mcsSprinklers Debug | bZoneIsRunning=,0,0,0,1,0,0,0,0,0,0,0,0
    6/23/2020 4:07:42 PM 637285252629138776 | mcsSprinklers Debug | rtiAreaStartTime(0)=120,1500,1500,1500,1500,1500,1500,1500,1 500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1 500,1500,1500,1500,rtiAreaStartTime(1)=120,1500,1500,1500,15 00,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,15 00,1500,1500,1500,1500,1500,1500,1500,rtiAreaStartTime(2)=0, 1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500, 1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,
    6/23/2020 4:07:42 PM 637285252629138776 | mcsSprinklers Debug | rtbZoneWateredToday=True,True,False,False,True,True,False,Tr ue,False,False,False,False,
    6/23/2020 4:07:42 PM 637285252629138776 | mcsSprinklers Debug | rtiAreaNextStartTime=120,120,0,
    6/23/2020 4:07:42 PM 637285252629198783 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 0/6/23/2020 9:55:03 AM,Value=57,Device=R1, rtbUseDeviceValue=False, iPreviousValue=57, iValue=57
    6/23/2020 4:07:42 PM 637285252629238799 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 1/6/23/2020 11:20:04 AM,Value=57,Device=R2, rtbUseDeviceValue=False, iPreviousValue=57, iValue=57
    6/23/2020 4:07:42 PM 637285252629238799 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 2/6/23/2020 4:06:36 PM,Value=57,Device=R3, rtbUseDeviceValue=False, iPreviousValue=57, iValue=57
    6/23/2020 4:07:42 PM 637285252629248782 | mcsSprinklers Debug | Remaining Minutes R4,sOnOff=ON
    6/23/2020 4:07:42 PM 637285252629248782 | mcsSprinklers Debug | Remaining Minutes2 R4,hs.isOn(sDC)=True
    6/23/2020 4:07:42 PM 637285252629248782 | mcsSprinklers Debug | Remaining Minutes4 iRemainingMinutes2=20
    6/23/2020 4:07:42 PM 637285252629248782 | mcsSprinklers Debug | FormatSprinkler Change=False, StatusChange=False, DC=R4
    6/23/2020 4:07:42 PM 637285252629258786 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 4/6/20/2020 2:04:00 PM,Value=55,Device=R5, rtbUseDeviceValue=False, iPreviousValue=55, iValue=55
    6/23/2020 4:07:42 PM 637285252629268784 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 5/6/23/2020 11:49:00 AM,Value=56,Device=R6, rtbUseDeviceValue=False, iPreviousValue=56, iValue=56
    6/23/2020 4:07:42 PM 637285252629278785 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 6/6/23/2020 12:09:00 PM,Value=56,Device=R7, rtbUseDeviceValue=False, iPreviousValue=56, iValue=56
    6/23/2020 4:07:42 PM 637285252629278785 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 7/6/23/2020 4:07:00 PM,Value=94,Device=R10, rtbUseDeviceValue=False, iPreviousValue=94, iValue=94
    6/23/2020 4:07:42 PM 637285252629288786 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 8/6/23/2020 4:00:30 PM,Value=82,Device=R11, rtbUseDeviceValue=False, iPreviousValue=82, iValue=82
    6/23/2020 4:07:42 PM 637285252629288786 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 9/6/23/2020 4:03:44 PM,Value=67,Device=R12, rtbUseDeviceValue=False, iPreviousValue=67, iValue=67
    6/23/2020 4:07:42 PM 637285252629298781 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 10/6/23/2020 1:49:00 PM,Value=67,Device=R8, rtbUseDeviceValue=False, iPreviousValue=67, iValue=67
    6/23/2020 4:07:42 PM 637285252629298781 | mcsSprinklers Debug | EvaluateWaterNow MoistureValueChange Zone 11/6/23/2020 3:16:54 PM,Value=69,Device=R9, rtbUseDeviceValue=False, iPreviousValue=69, iValue=69
    6/23/2020 4:07:42 PM 637285252629328800 | mcsSprinklers Debug | rtiWaterTankLevel=0, rtiPreviousSiteWater=0, rtiWaterTankLevelMax=0, rtiWaterTankLevelMin= 0, DeviceOn=True, bTankState=True, nTankLevel=0
    6/23/2020 4:07:42 PM 637285252629368801 | mcsSprinklers Debug | iManualStatus=1
    6/23/2020 4:07:42 PM 637285252629368801 | mcsSprinklers Debug | Water Use Area 0=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629388840 | mcsSprinklers Debug | Water Use Area 1=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629398795 | mcsSprinklers Debug | Water Use Area 2=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629398795 | mcsSprinklers Debug | Water Use Area 3=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629428807 | mcsSprinklers Debug | Water Use Area 4=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629438836 | mcsSprinklers Debug | Water Use Area 5=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629438836 | mcsSprinklers Debug | Water Use Area 6=0, Limit=0, Period=0
    6/23/2020 4:07:42 PM 637285252629448822 | mcsSprinklers Debug | Water Use Area 7=0, Limit=0, Period=0
    Plug-Ins Enabled:
    What I see is that the GoControl status has not updated following a command. mcsSprinklers tries 4 times to get a good handshake. In the below extract I see the retry thread was still active at the time the On command was given so it superseded the On. This was only a quick glance at the data. I will look into in greater depth later.
      The acknowledge from HS that the GoControl received the command is not being received by mcsSprinklers following the command to change the valve in the 15 seconds that mcsSprinklers is waiting for it before it sends a retry. What I am guessing is happening is the event from HS is happening in the same thread as the thread where the 15 second monitoring is happening and in your case it is not delivered until after the monitoring is complete.
      What I did was put the command in a new thread so this will assure it is decoupled from the thread that HS used to communicate with the plugin. The update is at http://mcsSprinklers.com/mcsSprinkle...0_0_21_HS3.zip. Unzip mcsSprinklers_2009.dll and HSPI_MCSSPRINKLERSP.exe into HS folder.
      Your debug record
      [COLOR=#e74c3c]6/23/2020 4:07:31 PM 637285252510501992 | mcsSprinklers Debug | GoControl Command R4 to ON for 21[/COLOR]
      [COLOR=#e74c3c]6/23/2020 4:07:42 PM 637285252628098739 | mcsSprinklers Debug | GoControl Parms(2)/Status=7684, Parms(4)/Ref=963, AcknowledgeExpected=2, ControlDevice=R4
      OFF')[/COLOR]
      My debug record
      6/26/2020 10:00:25 AM 637287624257030590 | mcsSprinklers Debug | Log Discrete INSERT INTO dR10 (SampleDate,Discrete) VALUES(#2020-06-26 10:00:25#,1)
      6/26/2020 10:00:25 AM 637287624257030590 | mcsSprinklers Debug | LogAction INSERT INTO log (SampleDate,Device,Status) VALUES(#2020-06-26 10:00:25#,"R10","ON")
      [COLOR=#2ecc71]6/26/2020 10:00:25 AM 637287624259883102 | mcsSprinklers Debug | GoControl Command R10 to ON for 2[/COLOR]
      [COLOR=#1abc9c]6/26/2020 10:00:26 AM 637287624261324848 | mcsSprinklers Debug | GoControl Parms(2)/Status=1282, Parms(4)/Ref=3118, AcknowledgeExpected=2, ControlDevice=R10[/COLOR]
        Your debug record
        OFF')[/COLOR]
        My debug record
        Thanks! I'll install it today and let you know.
        Plug-Ins Enabled:
          I uploaded the file again at 10 AM Pacific time because I had my IP used for testing on my HS3 computer hard coded. I fixed that in the new updload.
            I installed it (for some reason my HS lost all events when I did this- maybe unrelated but I was able to restore a configuration from that morning.)
            So far, so good...
            One thing I noticed is all of my zones have synchronized to the same moisture level. Zones 1-7 are area 1, and 8-12 are area 2. All have different factors and I don't sync them.
            It watered area 1 last night, we just got some rain recently- and you can see zone 8 (area 2) jumps up to meet zone 7 (area 1) pretty quickly after it rains. I am not sure this is new, but that doesn't seem right. Area 2 is now pretty dry.
            Before I installed this update, this moisture graph was not showing properly.
Name:	Screen Shot 2020-06-28 at 12.28.58 PM.png
Name:	Screen Shot 2020-06-28 at 12.22.25 PM.png
Name:	Screen Shot 2020-06-28 at 12.16.30 PM.png
            Plug-Ins Enabled:
              Can you provide the debug that spans the time when you observed the moisture level jump. Either attach the file as a zip or email it to mcsSolutions at CenturyTel dot net. I would also like to compare the control vs. the control that you posted in #1. It would also be nice to have \Config\mcsSprinklers.ini so I am not guessing at the setup.
                Sent!
                Plug-Ins Enabled:
                  I saw the issue with the sync. I am surprised it did not show up at compile time as misplaced parenthesis resulted in an array index being a boolean rather than integer value. I suspect it was converted to a zero and then this made Area 2 look like it needed syncing after the round robin was completed for Area 1. The update is at http://mcsSprinklers.com/mcsSprinkle...0_0_24_HS3.zip. HSPI_mcsSprinklersP.exe and mcsSprinklers_2009.dll from the zip go into the HS folder.
                    I believe I updated and still saw the issue. (copied the DLL and EXE to the HS folder and started the plugin)
                    I then uninstalled the plugin entirely: deleted all MCSSprinkler files, devices, and ini files... installed the plugin and installed the 24 beta. Ran through the setup and now everything is looking great. Each zone is computing its own moisture and that value is sticking. Before it was synchronizing them all together every few hours.
                    It is pulling the information off of my weather station and I see the next predicted watering time push out as the rain falls!
                    Thanks! I'll keep an eye on it, but hopefully won't have to touch it.
                    Plug-Ins Enabled:
