With HS3 and V mcsSprinklers Version 2.19.11.0
    Started up the HS3 and V mcsSprinklers Version 2.19.11.0 and no connection to Rain8.
    As I checked further the mcsSprinklers screen for interface changed, was different?, incomplete, not sure but as I checked, did not see the a connection to the serial device. Looked through the interview for questions to configure.
    For the Rain8 i have the setup captured in the attached screen shot. Do you see any issue here for 2 Rain8 modules,
    1 master and the other 1 slave in the configuration I should check on?
    Thanks.
    should check? Click image for larger version
Name:	Interface July 11 setup.PNG
    Serial shows,
    7/11/2020 9:03:06 PM | 03829000 | NET(0) OUT | 40, 01, F0
    7/11/2020 9:03:11 PM | 03834000 | Net Send Timeout
    7/11/2020 9:03:11 PM | 03834000 | NET(0) OUT | 40, 01, F0
    7/11/2020 9:03:16 PM | 03839015 | Net Send Timeout
    7/11/2020 9:03:16 PM | 03839015 | NET(0) OUT | 40, 01, F0
    7/11/2020 9:03:21 PM | 03844031 | Net Send Timeout
    HS3 Standard Edition 3.0.0.258
    The setup is to use a IP 192.168.0.160 port 512 raw data passthrough for a rain8 master and slave. The command being sent did not get a response from the Rain8Net. First place I would look is at the IP/Serial device at 192.168.0.160:512.
    There may be more info in the mcsSprinklers debug if you have that enabled.
