updating mcSprinklers plugin
    Edit: from what I can tell the new version is applied, but HS is just reporting the incorrect version in the plugins menu.
    I am trying to upgrade to the P_2_20_4_33 version using the "Other Setup" page. I had only every been updating the plugin through the HS store updates until recently learning of the method on the page in setup. I attempted the update and after a min or so HS came back up, but the plug page still shows me as being on 2.20.0.18 even though the update page in the plugin shows the _33 version was applied. Am I doing something wrong? I had no idea mcsSprinklers had its own update mechanism outside of HS3.
    You are doing nothing wrong. There are two parts to the plugin. One is the HS API (HSPI_MCSSPRINKLERSP.exe) and the other is the irrigation logic (mcsSprinkers_2009.dll). The Other page only updates the irrigation logic. The HS API does not have logic changes very often, but I do update version number when it goes to the Updater. You can tell the mcsSprinklers_2009.dll from the Other page. I think it also shows in the status device 99 and in the standalone version it shows on the header of every browser page.
      Thanks Michael. That makes sense.
