reset sprinkler device "lowest soil moisture" ?
    Hello,
    My sprinkler device "lowest soil moisture" (S84 in my system) keeps registering in negative territory an area/valve that is no longer being used. This valve is not assigned an area; in the layout page the area is set to "none" . However, on the general status page it, device s84 lowest soil moisture, keeps updating daily and getting more and more negative. I cannot seem to find this device anywhere else in HS3.
    How can I reset this sprinkler device so that it will refer to my active areas?
    Thank you in advance
    Download http://mcsSprinklers.com/MCSSPRINKLERS_22100.zip
    Unzip into \bin\mcsSprinklers folder
    Restart plugin
      I did that, thank you!
        I just noticed that the nice little green graphics of soil moisture have disappeared from the zone status page. What I see is no graphic but the percent soil moisture for each zone is reported at the end of where the graphic should be. I am not saying the problems are related, maybe I just noticed it, although, a few days ago, after you helped me get the weather data into your program, I am sure the graphics were there as I was enjoying watching them change.
          The graphic is dynamically determined using the range of data from the database. Can you provide \data\mcsSprinklers\mcsSprinklers.mdb and I can see what happens when I draw it.
            I am getting a max post size error when I try and upload my mcssprinklers.mdb file, it is 260,000 kb. It has dates going way back to 2010, with lots of zeros all over the place. Is there a way of rebuilding this file from scratch? I have a file in the same directory called "mcssprinklers-original.mdb"
              You can use compact and repair if you have Microsoft Access. I also wrote a utility to do this a long time ago. You can also zip it up and email to mcsSolutions at CenturyTel dot net.
                Thanks, I sent it to you by email.
                  The problem described at the beginning of this thread has returned. It went away until now after I downloaded the file you provided, but now the exact same problem has returned. Thanks in advance.
                  Originally posted by Ricky View Post
                  Hello,
                    Are you indicating that after you did a compact and repair (via tool) on the Access database that the problem returned? Since moisture level is maintained in the database it implies that the "fixed" database has a zone in an active area that is showing a negative moisture level. Can you look at the database? It should be smaller now. Can you email it?
                      I started with a new database. I sent it to you by email. Thanks
