Weather download issues
    Hi Michael, sorry to bother you. I'm trying to download data from the weather stations but no matter what I select, it comes up with zero results. This is one example of what I'm getting. FYI, I was getting a message from Weatherstack that I was using too many requests. All other weather stations report those values in the print screen.
    It looks like that darkshy is pretty accurate, I believe I use it in weatherxml. Could you integrate it in your Plugin?
    Sent from my SM-G973U1 using Tapatalk
      There is a related thread in this forum. Suggest you follow that one. Weatherstack has a limited number of free downloads per month.
      Looking at Open Weather Map it appears it has engulfed Dark Sky. It is a good site, but does not report actual rainfall. Only forecasts.
      Weatherstack seems to be best for actual rainfall. I am in the middle of adding a rainfall only provider and doing it in a manner where Weatherstack can be used.
      if you are happy with what you are getting from WeatherXML you can use use the HS device and not download with mcsSprinklers.
        Thank you Michael, I was reading the other post but I assumed it was just an update of the Plugin which I did. I did not go thru in detail enough I need to confess that there were more issues and you were trying to fix them.
        Thank you,
        Aldo
