Can I capture projected run date/time in an HS device?
    I would like to add basic irrigation data to my automation system's Daily Report script. I can get the last run time for each area from the "S45 - Area 1" device using hs.DeviceLastChangeRef(idnum). But I also want to add the current moisture level and predicted next watering date/time as shown in the Run List. Is there a way to grab that data?
    The Other Page, Homeseer Options, has checkboxes to create predict devices and moisture devices. If you have a valve at R1 then devices will be created at R101 and R202 to hold these parameters. If you have 10 zones then you will get 10 or 20 new devices depending upon the checkboxes you select.
      That's exactly what I need - thanks!!
