HS4 Backup Warning
    HS4 Backup Warning
    I'm getting these warnings every day during the built-in HS4 backup process. These files will be missing from the backup if it's ever needed.
Name:	Screenshot 2022-06-13 121127.png
    They will not be needed in the backup. These are the weather downloads and the messages/startup log. It really seems like the backup should be doing read-only copy so that files that are currently open will be included in the backup.
      From the text of the yellow highlighted line above, it sounds like they expect you to implement something.
        Last time I looked there is no Backup Event defined in the API. I question the wisdom of having such an event. If HST wants the plugin to close all its files and then open them up again when the Backup-Done Event is raised, then really what they are asking is doing the same thing as stopping and starting the plugin. They have full control of the stop/restart.
        In my opinion, the backup operation should be transparent and not shutdown system capability while the backup is occurring. Look at other commercial backup software such as Acronis. It does not require Windows to respond to some event raised by Acronis to close down all Windows open files.
