Best way to disable rain forecast because of inhibit
    Hi, I have some issues with the rainforcast. The forecast of the weather is very hot and sunny but within the plugin i got constantly an inhibit about the forecast rain. Because in that way i need manually sprinkling and i don't want that. So i would like to disable all forecast input.
    See the picture. I unchecked these settings. But still after a 5 minutes the "rainforecast inhibit" is still active. What do i have to do more?
Name:	rain inhibit.jpg
ID:	1557627‚Äč Click image for larger version
Name:	weather setup.jpg
    The Site Setup Page contains the global rain inhibit settings. Uncheck forecast rain will no longer be considered as an inhibit.
    The setting for Forecast has a 0 percent probability. If you want to use this forecast in the future you will want to change it since a site that provides the forecast will use 0 when no rainfall is forecast.
