I have a setup with 6 valves, each with a matching Zone and Area. I currently wish for one of the Areas to run every day for 15 minutes. It seems that the calculated Soil Moisture or some other setting is keeping the scheduled time from turning the valve on. Is there a way to either set the soil moisture or have this ignored and force a daily watering? I am not sure where the calculated level is coming from but it is not accurate at this time a we have not had rain in a few days, maybe a week ago?. Any runs I have done of the irrigation system have been manual testing while getting valves and drip emitters into place. Attached is my INI file and debug file in case they help. I had to change the extensions (.ini and .gz) to allow for upload.
My goal is for Area 1 to use the HomeSeer soil moisture sensor (device 2323) and ideally run at a specific time (6 PM) although the time it runs can vary if needed. Area 2 should run every day at a given time. The other areas are not currently set up with valves, etc. so they can be ignored for the moment. I am sure there is some setting I am missing, but can't figure out what that may be.
