Disappearing Area 1 Valve 1 details
  • Disappearing Area 1 Valve 1 details
    If I make updates to Valve 1 in Area 1 (Zone Setup) and save changes the whole valve entry is deleted. I was just changing the crop value. Note that I had only one valve definition for area 1. I am running 2.2.121. Thanks Again.
    Rick
    Anything in the log that indicates some error during the setup operations?
    I played around with various combinations and no unexpected seasonal percentage loss or problems with a single zone in Area 1.
    You can post your mcsSprinklers.ini so I can play with it and look for anything unusual.
      I did find the following errors. Note this first error appears to be the disappearing zone 1 area 1 valve When I tested the V.2.2.132 version after installing.
      5/12/2005 9:14:51 PM~!~mcsSprinklers~!~AcceptZoneChanges Valve [HS O9] Piazza does not exist in inUse Dictionary
      5/12/2005 9:14:52 PM~!~mcsSprinklers~!~GetLastMoistureAndMinutes Field a493MinutesCum___I, Error=Invalid use of Null Line 290 Invalid use of Null
      5/12/2005 9:14:52 PM~!~mcsSprinklers~!~GetLastMoistureAndMinutes Field a493Moisture_____I, Error=Invalid use of Null Line 200 Invalid use of Null
      5/12/2005 9:14:52 PM~!~mcsSprinklers~!~GetLastMoistureAndMinutes Field a492MinutesCum___I, Error=Invalid use of Null Line 290 Invalid use of Null
      5/12/2005 9:14:52 PM~!~mcsSprinklers~!~GetLastMoistureAndMinutes Field a492Moisture_____I, Error=Invalid use of Null Line 200 Invalid use of Null
      5/12/2005 9:15:24 PM~!~mcsSprinklers~!~GetLastMoistureAndMinutes Field a493MinutesCum___I, Error=Invalid use of Null Line 290 Invalid use of Null
      5/12/2005 9:15:24 PM~!~mcsSprinklers~!~GetLastMoistureAndMinutes Field a493Moisture_____I, Error=Invalid use of Null Line 200 Invalid use of Null
      5/12/2005 9:15:24 PM~!~mcsSprinklers~!~GetLastMoistureAndMinutes Field a492MinutesCum___I, Error=Invalid use of Null Line 290 Invalid use of Null
      5/12/2005 9:15:24 PM~!~mcsSprinklers~!~GetLastMoistureAndMinutes Field a492Moisture_____I, Error=Invalid use of Null Line 200 Invalid use of Null
        Here is my ini file...
          These problems are all caused by a blank house code for your Rain8Net devices. I do not know why it is blank, but I do know a problem with a typo in the area trying to achieve HS2 compatibily that generated the Accept Zone Changes error message every time any setup page save was done this could of affected various things.
          If you have a pre HS2 version of your ini file saved then you should be able to go back to it otherwise it is safer to start over rather than edit of the ini file. Use a version later that 2.2.139 which I will past later today.
