Jim, run the script with DeviceString rather than DeviceValue since mcsSprinklers uses the string. It does appear, however that DeviceString is being populated by VWS since there are decimal values showing. You can also post the mcsSprinklers.ini so we are clear about the setup you are trying.
Homeseer Interface
Michael,
Yes, that is where I have been entering the vws ]xx Codes. I searched for them and you are coreect, they were not in the ini. I hit "Save Changes" on the Other page and reopened the ini and Humidy appeared in the ini but the other three were not there. I hit Save Changes again, reopened the ini and all four are now there (attached). The values on the General page are 0s.
JimAttached Files
Plugin version
Ka7gzr,
Like you, my vws devices are stared with a "]". I'm using version 1.0.0.1 of the plugin with HS 2 build 1950.1. I stared using the plugin with HS 1.7. Assigning the appropriate devices on the other setup page of mcsSprinkers has captured the correct values in mcsSprinkers.
The problem may be with the verison you have. Where/how did you get a version 2. I can't find anything other than a version 1 of the plugin on the Ambient site.
Cecil
Cecil
I just purchased it a week ago. I got it here:
http://www.ShopAmbient.com/vws/
I don't know if your password will work.
It does appear that v1 works and something changed with this v2.
Jim
Jim,
Downloaded 2.0.0.8 from the link you specified. Uninstalled 1.0.0.1 and re-installed 2.0.0.8. Was able to duplicate the problems you described -- specifically the humidity and temp did not change and/or changed to zero values. Uninstalled 2.0.0.8 and re-installed 1.0.0.1 and the problem went away. Ambient must have changed something significant in 2.0.0.8.
As best i can tell 1.0.0.1 works just fine. It does generate an error upon startup about not using the correct method to enumerate devices (and change in HS2 from HS1), but the values all work correctly.
If you do decide to try 1.0.0.1, be aware that when you go into setup, the windows dialog will appear behind the HS browser window. You have to minimize that windows (and perhaps several others) before you can see the dialog. HS will seem to be stuck, but it is simply waiting for you to respond to the hidden dialog box.
Cecil
glentodd
Because of the way that it's marketed, I can't post it directly (it IS a commercial product), but I will provide a copy to Ed Edelman of Ambient, and in the mean time you can get updates by emailing me directly at glen@glentodd.net.
