Strange Happenings in v2.9.0.54
    Ever since I upgraded to the new version, I'm getting very strange results. My zones keep turning on and then immediately off (on about an hour cycle). This is the log after a reboot of the system. I finally had to do an emergency shutdown to get it to stop.
    9/17/2009 8:32:31 AM ~!~mcsSprinklers~!~Event 4 P50=P Discarded because setup change initialization not complete
    9/17/2009 8:32:39 AM ~!~mcsSprinklers~!~Event 4 ]69=] Discarded because setup change initialization not complete
    9/17/2009 8:32:41 AM ~!~mcsSprinklers~!~Event 4 )3=) Discarded because setup change initialization not complete
    9/17/2009 8:32:41 AM ~!~mcsSprinklers~!~Event 4 V35=V Discarded because setup change initialization not complete
    9/17/2009 8:32:42 AM ~!~mcsSprinklers~!~Timeslot forced to last schedule of day because not all zones have completed yet
    9/17/2009 8:33:12 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 2 )2: Back Yard OFF
    9/17/2009 8:33:13 AM ~!~mcsSprinklers~!~ProcessRain8Response Line 570 The process cannot access the file 'C:\Program Files\HomeSeer\Data\mcsSprinklers\IOWindow.txt' because it is being used by another process.
    9/17/2009 8:33:13 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 3 )3: Side Lawn Upper OFF
    9/17/2009 8:33:13 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 5 )5: Side Lawn Lower OFF
    9/17/2009 8:33:13 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 4 )4: Front Yard OFF
    9/17/2009 8:33:13 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 1 )1: West Beds OFF
    9/17/2009 8:33:13 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 2 )2: Back Yard OFF
    9/17/2009 8:33:14 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 3 )3: Side Lawn Upper OFF
    9/17/2009 8:33:15 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 5 )5: Side Lawn Lower OFF
    9/17/2009 8:33:15 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 4 )4: Front Yard OFF
    9/17/2009 8:33:16 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 1 )1: West Beds OFF
    9/17/2009 8:33:21 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 2 )2: Back Yard OFF
    9/17/2009 8:33:23 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 3 )3: Side Lawn Upper OFF
    9/17/2009 8:33:24 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 5 )5: Side Lawn Lower OFF
    9/17/2009 8:33:26 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 4 )4: Front Yard OFF
    9/17/2009 8:33:27 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 1 )1: West Beds OFF
    9/17/2009 8:33:27 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 2 )2: Back Yard OFF
    9/17/2009 8:33:27 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 3 )3: Side Lawn Upper OFF
    9/17/2009 8:33:29 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 5 )5: Side Lawn Lower OFF
    9/17/2009 8:33:29 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 4 )4: Front Yard OFF
    9/17/2009 8:33:31 AM ~!~mcsSprinklers~!~Rain8 Unit 1, Valve 1 )1: West Beds OFF
    Regards, Bob
    I do not think there is anything unusual in this log? What version were you running prior to the upgrade? If there is a debug log when it was failing that would be good, but at least the mcsSprinklers.ini so I can see you setup.
      Michael,
      Here is the ini file.
      Regards, Bob
        I assume your prior version was before 2.9.0.46. In that version status callbacks were enabled to allow users to select any HS virtual device as alias. This seems to be causing problems when I tried with your setup. I tried to deal with it in 2.9.0.55. I could no longer replicate the problem I was seeing with 2.9.0.54.
