Hello Michael,
I recently upgraded my HS computer to Win7 x64. I wasn't sure which folder to migrate HomeSeer to (c:\Program Files\HomeSeer HS2 or c:\Program Files (x86)\HomeSeer HS2) and having read a recommendation I moved it to simply c:\HomeSeer HS2 (I figured it would be easier to migrate back to 32bit should the need arise).
mcsSprinklers seemed to work fine. Without a thorough inspection, at least I could navigate through all the setup pages.
Today I upgraded mcsSprinklers to 2.9.0.57 (I don't recall the previous version now, but it was very close). Now mcsSprinklers won't load any web pages, just a blank page no errors [example load myURL= /mcsSprinklers/mcsSprinklers.asp?Page=hs) - this asp file exists. I tried from HS setup menu both config links as well.
I did find that mscSprinklers.ini stil had references to c:\Program Files\HomeSeer HS2 (DATABASE= and 4 wiring pictures) so I edited the paths. I again reinstalled from the updater (just over top) and still can't access anything. I've been all through config folder and html\mcsSprinklers folder and can't find any bad paths.
HomeSeer acknowledges the plugin, and it shows licensed, but I don't see any mcsSprinklers startup messages (other than the plugin found) in the log after rebooting.
In settings.ini there is an mcsSprinklersP in "io_interfaces= "
mcsSprinklers_license.ini file is 0 bytes with the latest reboot timestamp
In c:\HomeSeer HS2\data\mcsSprinklers, the mcssprinklers.mdb database is 2.7Mb and is updating with the current time.
I've attached the log files.
Hope you can help!
Hope you can help!
