Strange Messages
    Strange Messages
    Recently I noticed a bunch of messages that I don't undertand, they don't really to seem to effect the operation of the software or sprinklers, but they must mean something. I pasted below.
    7/14/2011 6:47:17 AM | ProcessRain8Response Line 565 The process cannot access the file 'C:\Program Files\mcsSprinklers\Data\mcsSprinklers\IOWindow.txt' because it is being used by another process.
    7/15/2011 12:08:21 PM | Rain8Net Unit 3 responded to valve 5 command=ON with status of OFF
    7/15/2011 11:39:36 PM | AssignNextAvailableTime Area=2, Zone=7, Day=1 Line 1650 Index was outside the bounds of the array.
    7/15/2011 11:39:36 PM | AssignNextAvailableTime Area=3, Zone=10, Day=1 Line 610 Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
    7/15/2011 11:39:36 PM | NextTimeToday Line 570 Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
    7/15/2011 11:39:36 PM | AssignNextAvailableTime Area=2, Zone=8, Day=1 Line 610 Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
    7/15/2011 11:39:36 PM | AssignNextAvailableTime Area=4, Zone=11, Day=1 Line 610 Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
    7/15/2011 11:39:36 PM | AssignNextAvailableTime Area=4, Zone=12, Day=1 Line 610 Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
    7/15/2011 11:39:36 PM | AssignNextAvailableTime Area=4, Zone=13, Day=1 Line 610 Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
    7/15/2011 11:39:36 PM | AssignNextAvailableTime Area=4, Zone=14, Day=1 Line 610 Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
    7/15/2011 11:39:36 PM | AssignNextAvailableTime Area=5, Zone=15, Day=1 Line 610 Source array was not long enough. Check srcIndex and length, and the array's lower bounds.
    Most of these occur in the prediction logic that is called periodically when certain pages are open. These do not affect any scheduling logic and only affect what is shown on a browser. The google search seems to indicate a possible concurrency problem. It all occurred in one burst in your case and hard to identify what precipitated it. It is not something that merits much time to understand since it is infrequent. I suspect that if multiple mcsSprinklers browser pages are open it may occur more often, but that is only a guess.
    610: For Each oTimes In TimesCollection(iScheduledArea, jDay).ToArray
    570: For Each oTimes In TimesCollection(kArea, jDay).ToArray
    The IOWindow.txt file was being written when a browser request was trying to view it. This resulted in the message. No ill effects other than I suspect the browser display was incomplete. 'C:\Program Files\mcsSprinklers\Data\mcsSprinklers\IOWindow.txt' because it is being used by another process.
    The following means that Rain8Net did not have the expected status response. This behavior is not unusual and that is what precipitated much failure detection and recovery logic within mcsSprinklers. Nothing to worry about when it is infrequent.
