Hi. I am having a problem since I moved homeseer pro to a windows 7 guest machine on an ESXi hypervisor.
I have everything working, but after some amount of time, 2-5 days, mcssprinklers (profession) stops functioning. When I try to exit homeseer to restart it, hs complains about not being able to find some html content and seemingly waits forever. Here is the log file output:
5/12/2013 10:32:28 AM ~!~Shutdown~!~Shutting down plug-in: mcsSprinklersP
5/12/2013 10:32:45 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/mcsSprinklers.asp?Page=sprinkler requested by default from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/StyleNoBody.css requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/OverLib/overlib.js requested by default from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/clock.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/sunrise.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/sunset.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /kesmall.jpg requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/Images/Calendar.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/Images/led-yellow.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/Images/green.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/Images/Sensors/blank1.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:32:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/Images/led-ltblue.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:33:46 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/mcsSprinklers.asp?Page=sprinkler requested by default from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:33:47 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/StyleNoBody.css requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:33:47 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/OverLib/overlib.js requested by default from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:33:47 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/clock.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:33:47 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/sunrise.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:33:47 AM ~!~Error~!~Error processing plug-in links for /mcsSprinklers/sunset.gif requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
5/12/2013 10:33:47 AM ~!~Error~!~Error processing plug-in links for /kesmall.jpg requested by from 10.0.8.66, at:0, Index was outside the bounds of the array.
This keeps on going....
If I kill homeseer through taskmgr and restart it, mcssprinklers still doesnt work. However, a full reboot of the guest vm works fine, and restores service fine.
When I say mcssprinklers dies, you can look at the run log and see that all communications checking with the rain8 modules stops. Weather checking with the wunderground sites in the logs also stops. And while you can access the plugin via the browser, it displays everything normally, but nothing "works". So when I go to the the zones status, and trigger a manual run, the zone says "manual control", and but the zone thsta is supposed to be running doesn't say watering now, and it says it's supposed to start at the current time, which keeps on increasing. There is no log activity of valve state changes, and no valve action occurs.
I did do a clean install of HS into the guest VM (I didnt use a P2V tool), but did bring over all the config files from the old hs system as the hs instructions for moving to hardware instructs.
Any ideas as to what's going on? This is a real problem since the weather is hot. rebooting the vm isn't that hard, but checking up on it is a pain.
Thx
Mike
Thx
Mike
